FICM testing beyond voltage? Melted injector plug
I have read that the FICM can still be bad even if I am reading all of the proper voltages. Are there any additional tests that I can conduct to verify FICM function other than voltage input/output? I am waiting on my AE bundle to be delivered next week. Does it have enhanced FICM testing? I don't have an extra FICM to swap out, unless someone here in the forum lives near me and would like to stop by.
Yes. I entered the xgauge values you provided and I got the same readings that you had. So that checks out ok.
Running out of things to check and the truck has been sitting WAY too long. I did swap out the injector harness because I found a melted plug located driver side second one from the firewall.
I am thinking this may have caused additional damage at the injector or backwards to the FICM. After the new harness was installed, I started the truck and could hear a ticking noise in the location where this damaged plug was. So I decided to bite the bullet and get AE. Towing and diagnostic fees pretty much equal the cost of the software, plus I know I will save $ in the future. Any suggestions?
I just went out to try and start the truck because it has been starting when left to sit for a while. Today my no hot restart has transformed into a crank no start. The engine skips while cranking and there is white smoke puffing from the tailpipe, both of which are new conditions as of today. I can't wait to get this "experience" behind me.
Still no codes from SGII even though my DTC count is up to 7.
agg_bagg
18
09-24-2015 06:51 PM
