2003 expi 'check advancetrac" and no 4wd???
I am getting a "check advtrac" and my 4wd will not activate. I have a friend with a diagnostics computer and it was showing "no output - 4wd controller", so i assume it's either a bad controller or it isn't getting power and i want to check that out myself b4 i spend the $$$$ to have someone else look at it.
Question is, where is the 4wd computer? If it's part of the PCM, where exactly is that? Is it a module that can be replaced seperately, or do you have to spring for the whole unit$$$$$???
Yep, the fuses are all good, but I haven't checked the fuse sockets. I did swap out the 4wd module fuse with one of the spares and it was still a no-go.
This whole thing started with an intermittent beep indication every 10 seconds or so from the Advancetrac coming on, going off, coming on, then going off. This would only happen in the winter and only when it was below about 60 degrees. Come summer time the problem went away. Advancetrac would work and I could get 4 wheel drive, but I never really needed either so I never bothered to fix it. This last winter it came back for a month or so, the beeping on and off, then it just stopped working completely.
Now, every time I start the car, the information screen on the instrument cluster snows ADVtrac OFF, ADVtrac ON, ADVtrac OFF...CHECK ADVtrac and there it stays. I also get the backlighting on the switchlight in the center console going off and on in unison.
Whenever Advancetrac doesn't work (which is never now), I can't get 4 wheel drive.
So with that, and from what I gather the Advancetrac system uses 4WD controller info, and the fact that the one time I hooked up to a dignostic I got a "no output - 4wd controller"(when I had it diagnosed, though, it wasn't the current problem - it was the intermittent problem), I am pretty sure the 4wd computer is either bad or has a bad ground or hot. Now that I know the problem, though, I need to know where this controller is and if it is a stand-alone unit or part of a MUCH, MUCH more expensive all-in-one electronics module. If it is, I don't need 4wd that bad.
FFJamison
6.7L Power Stroke Diesel
03-26-2016 04:47 PM
underdogl3
1997-2006 Expedition & Navigator
02-18-2016 07:00 PM
F250_E4OD_460_2WD
01-30-2016 08:41 AM
