Timing sure sucks...
Rain here for several days so I need the Bronco on the red clay road as opposed to driving the '11 Mustang GT. So.....taking the wife to a Dr. appt. and knowing the drivers side front disc brake rotor is grooved, I keep an ear out for odd sounds. Crap....really grinding now on the way home.
Had hoped for it to last another week or so since my right arm is having an issue with not having any grip but no luck. Go to my friendly local shop to see about the damage control.... $250 estimate....
Three hours later, new pads, two new rotors, bearings repacked, auto hubs greased, and rear brakes checked.....and $239.13 out the door. A guy has to do what he has to do.....
Oh well....Merry Christmas to my Bronco.
Well, sometimes you DO have to do what you gotta do... er.. ah...
But if it really bothers you, you could grab a chain and go around beating yourself with it like they do in the middle east. No, with your arm problem, better not.
Anyway, just think of all of the $$ you have saved to-date by doing things yourself.
Is it stuck on the EGR tube? if so, took me months to finally get mine off. I was also worried about pulling the bolts for the EGR valve out of the intake, I'm already one bolt size up because of the softness.
Lots and lots of PB, then finally found an adjustable wrench I could fit a long pipe over the end of. Probably took a couple hundred pounds of force to break free, the wrench flexed, the motor twisted, the pipe bent, it was not fun. Though I think 'tapping' the fitting with a BFH is really what made it finally break loose. Make sure it's nice and lubed before you get it to turn at the fitting or you'll twist your EGR tube into two pieces.
swapping my valve out made a huge deal in how my motor run. It was acting like the valve wasn't seating or the diaphragm was punctured, but in fact it was the body of the valve that was leaking (the gasket where the top and bottom connect), so I had a constant vacuum leak from it.
you dont need heat, just lots of PB and a 3+' long breaker to get it off.
442john
02-24-2009 04:52 AM
bigdaddyII
01-27-2005 01:32 AM
