Rust on engine components, help!
I just bought my first Ford Pickup, a 2008 F150 Limited. I raised the hood today and noticed that some of the components have a good bit of rust on them (pulleys, manifold, clamps, headers, steering gear/linkage, etc.) There are like actual rust flakes built up on top of the headers where they start to curve down and out. Some of the bolts look as if I couldn't get them out now if were to try. I am worried that I have been duped, even though I didn't look good at the engine before buying. Do I have serious problems with these components or is this common and cosmetic? Is there something I should do to get them cleaned or take it back to the dealer?
Thanks for your wisdom in advance!
BTW, I have always been a Chevrolet guy but I am now FORD all the way and I cannot believe I waited this long.
My truck was a GA truck for 4 years, and has spent the rest of its life here in VA. My headers show rust, but it's just surface rust. Afterall, they are iron and will show it well.
From what I can tell in the pics, like the other guys have said, it's just surface rust. You could take a wire brush (brass works well) to those areas around the steering linkage, etc, and then put a light coat of VHT paint on them, or some fluid film. Either way, those small areas do not seem to uncommon.
ek9beezler
01-10-2016 11:36 AM
loudoun
07-16-2014 12:22 AM
nmclella
11-03-2013 01:46 PM
