Correct Assembly of 2 piece fuel pump eccentric on 460?
I took this apart over a year ago and cant remember how it goes. Does the outside part float between the timing cover and timig ngear? Or does the outside piece get assembled so it cant walk off? I tried this and cracked due to there being nothing to support the area directly behind the bolt and washer. Please help i am trying to assemble tonight
The outside floats (spins) on the inner piece, this is to help reduce wear at the junction with the fuel pump.
But, it can't walk away, either.
Last edited by ctubutis; 12-22-2011 at 02:24 PM. Reason: Removed image from Parts Ctalog as it's confusing; image from Engine manual below is more specific
scottie2hottie
04-18-2008 11:12 PM
