are you plugging into the IPR itself? If so maybe its the ipr pigtail. Mine was all frigged up from the heat and taking it in and out. Glad to hear your making progress
New o-rings on the fpr,and sec fuel bowl. I have a cluster ordered. But i dont feel like thats it. It seems i cant command the ipr with my scanner,but when i hook my hillbilly harnness to it and to 12v to it,it closes. Im from alabama. Its cool..... So,why cant i command the ipr with my scanner? But i can with my home made harness? Wat tha hell!!! Im pullin my brains out with this thing.
once again load test thje harness using a high beam lamp. have seen a few with connector issues.
New harness cheezit. Ive got a cluster ordered. Gotta do the ford "handshake"with the pcm.
Cheezit,have you ever heard of a shorted inj solinoid? Im gettin a hard fault with num 8 inj. I wonder if unplugging it would let the truk start. Ive seen one little bity chaffed wire cause a no start.
Ima try it dukie. I got a extra ipr harness. Worth a shot..
What code? If the solenoid is messing with the FICM I can see where it would shutdown and that's certainly possible as are shorted solenoids.
I unpluggef 8 and no change. No change,that reminds me of obama and his wicked staff.i sent my num cheezit. Did u receive it? Silly question,are u useing ids from ford cheezit? My modis wont display fpr pid on 08 6.4...i got one with a inj pump wire harness prob.
