Vacuum Question
Vacuum Question
Just had a question about my vacuum lines (I'm sure you guys get a lot of them)
I have these two canisters on the passenger side with 90% of the vacuum lines coming out of it. When the engine is running, the lines have no vacuum whatsoever. (one upper one lower canister)
Lines that go to them are all from the carb (sans dist vac advance), and one from water neck
The largest ports on the carb (Front and rear) also have lines going to them, but I had them off for this.
So the question is, what are these canisters? And are these lines really vacuum lines? There are no lines heading to the manifold from there, so there is no source of vacuum.
Thanks
Jameson
Thanks
Jameson
This is part of you evaporative emissions control system. Most of the lines are vacuum lines. There should also be a line that goes to the fuel tank(s).
Here is an illustration from the Ford parts catalog to give you an idea of how its set up.
Also, some set ups used dual charcoal canisters. Sounds like that's what you have.
Click on the .pdf link to view.
I'd save them just incase you have to install them again in the future.
If memory serves me correctly, the purge valve on top of the canister is sourced from ported vacuum. If that's the case, you won't have vacuum anywhere at idle in the first place.
Most of the lines in and out of the canister are evaporative lines and not vacuum lines. You'll have one from the tank (tank fumes) and one from the carburetor (fuel bowl fumes). The output of the purge valve dumps to the air cleaner to get burned.
So if I take the charcoal canisters out, and remove the emissions lines going to and from the carb, will I need to plug all the openings on the carb?
Thanks
Jameson
If you don't cap them: A. The gas in the bowls will evaporate faster. B. You are more likely to get water/condensation in the float bowls. C. Since the bowls are already vented into the air cleaner it is possible that you may pull a draft through the float bowls and get dust/dirt in the carb.
Out of curiosisty where is that vacuum line running, the aluminum one that comes out directly above the choke cap? That is just a fresh air tube and does not pull a vacuum.
The one in front of the ID tag goes to the water neck. The other one (larger of the two) goes to the top charcoal canister
Coming off the bent metal line from the tank, is a length of rubber tubing. On the end of that, there is a plug. The truck was that way when I bought it.
Trucks with the charcoal canister vented the tank through the system so they used a non-vented cap.
You can leave that one uncapped. There is a check valve in the fuel tank. If you do cap it be sure to change your fuel cap to a vented cap or you'll start to have fuel delivery issues.
Oh I didn't realize that mattered. Since I don't have vented caps, should I uncap the fuel vapor line?
jasonzbtzl
10-23-2012 10:42 AM
mcguyver
07-26-2002 05:20 PM
