Need Help Removing Front Axles out of Dana
Have 2006 F250 4wd, i'm replacing the axle seals (at each end of the axle tubes AND behind the hub assembly). I can't get the axles out!
There are no axle retaining clips at the differential. It will only budge about 1/4". I've tried pushing in, then jerking it out. Also tried prying out on the u-joint from the cast iron spindle assembly (yes, the hub assembly is out).
What's the trick? Please don't respond unless you've actually done it yourself. I'm tired of getting advice from guys who've done it on the older trucks and the NAPA parts guys. My two local Ford service guys aren't very helpful either (one told me to pull the diff cover and pull the axle retaining clips off the axles - they aren't there thanks).
Any help is greatly appreciated. I'm at my wit's end!
I got it! NOW ? about assembly
I guess I didn't get mad enough. I beat the heck out of the seal from the inside and drove it out.
Now, installed the new style axle tube seal then installed the axle with the new outer seal assembled.
The axle doesn't seem to be in all the way. I remember seeing the axle protrude inside the differential just about 1/16" before I disassembled it. Now, it's just flush. But when I drive the axle in it bounces when I hit it as if it were bottomed out on something. Any thoughts?
PS What kind of lube does the front diff use?
PPS What grease do you use on the lock outs?
Thanks
Thanks
Thanks
Thanks
ethand320
04-24-2014 06:14 PM
KoolAidMan888
1999 to 2016 Super Duty
19
03-12-2011 08:30 PM
