What's your winter project for this year?
I'm pretty tapped out in the money department so I decided to sell my Harley and use the money to install a heidt's crossmember/ coil suspension/power steering kit. I still wanted a bike for occational rides so I bought this 2000 Honda VT1100 (I found it about 120 miles from home) that was previously laid-down. I thoroughly cleaned and polished the bike from top to bottom, then I replaced the damaged exhaust system, the damaged front right directional, the torn passengers backrest, the scraped up headlight bezel, the broken left passengers foot peg, and repainted the front fender. I also installed the new saddlebags, headlight visor, and added a few Honda vinyl emblems (on the side covers, I made them at work). This switch-a-roo should free up enough for the mustang II kit and four new tires.
Wally
1951 F1 - "Lucille"
Wally
1951 F1 - "Lucille"
I want to get all the metal work done on the cab of my chopped 56. Going in two weeks to pick up my new-to-me OEM tinted windshield (Thanks again, Kevin) then finding someone in the area that actually knows how to cut the glass down and get the windshield fitted... after the top-secret dash mods are finished.
If the cab gets done, then we will customize the fenders and see if we cant get it looking like a complete truck... Then wiring and all the little things.
And at some point (soon) stretch and hardtail my 75 Yamaha XS650 and get it back up and running.
Received 4,132 Likes
on
Wally
1951 F1 - "Lucille"
Wally
1951 F1 - "Lucille"
It's just that you did such a great job on the bike and the truck, and even the trick photography! (the limo thing, with the pool in the bed!)
Ok I will shut up now.....LOL! Happy Holidays!
I am going to make my 56 F100 a better daily driver. It now has a 68 472 Caddy & 400 trans. I had planned to replace the Caddy with a 302 Ford that I have. However, I just bought a 500 Caddy & 400 trans so I 'm thinking now about just replacing the 472 with the 500. I believe that the 472 needs a valve job.I have a spare 425 Caddy. I might use the 425 heads on the 472 after getting the valves ground on the 425 heads.I will save the 472 for another project.
I will c-notch the F100 frame and move the rearend above the springs so the truck will then be low & level. It has a volare ifs already installed.
I will have to install wipers on the truck, too.I'm thinking that I"ll buy one of the aftermarket kits that includes the motor, switch , and wiring.
The truck has the original red paint with a (red) repaint over the original. I plan to strip it and repaint it red. I think I will use tractor paint from Tractor Supply and "flatten" it to a low gloss.
The original radiator leaks. Does anyone know what model Dodge truck radiator is a bolt-in replacement?
Merry Christmas.
Merry Christmas.
#29
Ok wallster, maybe I am a little OCD but...the wing on the Honda Decal is flying backwards....I know...I know...not trying to be offensive, I promise!
Wally
1951 F1 - "Lucille"
