4 Cylinder/Manual Ranger gas mileage? - Page 2 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-09-2014, 11:59 AM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
my 2000 2.5 got 27-29 mpg.
Because of my upgrades, I'm lucky to get 20 mpg
Old 04-09-2014, 12:56 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Originally Posted by bowtieboy77 View Post
The next highest ratio would be 3.08. Is it your opinions that it would turn it in to a zero torque truck in 5th?
Yes. We had a '90 2.3 5-spd with 3.08 gears and it was the slowest thing I have ever driven.. could not maintain hwy speed into a headwind and OD was nearly useless on the highway. The thing spent most of it's life floored but it still returned a solid 25mpg everywhere all the time.
Incidentally our two 3.0L 5-speed trucks also return much the same gas milage but are much nicer to drive.
Old 04-09-2014, 01:52 PM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
3.08s in a 2.3/2.5 powered Ranger is a terrible idea, it's just too much weight to push around with the amount of power available. Even with the 3.73s in my old 99 I still wished for more gear.
Old 04-09-2014, 02:20 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
My '91 Ranger with 2.3 Lima engine, 5 speed w/OD and 3.08 gears was fine. True on a long moderately incline, I had to drop into 4th gear, otherwise if was more than adequately powered for 70 mph running, even pulling a trailer.
Old 04-20-2014, 07:25 PM
FarmingF250's Avatar
FarmingF250 FarmingF250 is offline
FarmingF250 has a good reputation on FTE.FarmingF250 has a good reputation on FTE.
I had a best of 35 MPG (CDN gallons) in a 93 2.3 5-speed. I don't recall the axle ratio, but I am guessing it was a 3.08 from the description others give. 5th gear was not usable going up any grade, including at 60 MPH. I remember one time on a 70 MPH highway not being able to use 5th on flat ground due a strong headwind!
Old 04-29-2014, 10:18 AM
finn finn is offline
finn is gaining momentum as a positive member of FTE.finn is gaining momentum as a positive member of FTE.
I've got an old (91) 2.3, 5spd Ranger Supercab 2wd with, I think, 3.08 gears. The truck was priced right (free) and the powertrain moves it along fine. I have to drop out of overdrive on some long hills, but that's a small price to pay for 24 mpg local and 28 mpg highway.
how much will 530 pounds affect my gas mileage? hrollin Ohio Chapter 3 05-18-2012 09:07 AM
78 1/2 F150 Ranger XLT 4x4 400 B/B Cowboy34 Alternative Fuels, Hybrids & Mileage 3 11-16-2005 06:36 PM
Looking for Gas Mileage Gains and HP Gains 0RangerEdge2 Ranger & B-Series 4 08-23-2005 11:11 AM
New 2002 4.0 ltr Ranger XLT Gas Mileage warrior26 Ranger & B-Series 9 04-17-2003 01:00 PM
f-350 v10 mileage greghoffmann 1999 to 2016 Super Duty 11 09-13-2002 12:05 PM
Tags
2002, 23, buying, cyl, cylinder, ford, forums, fuel, gas, good, lima, mileage, pcv, ranger, thinking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
