Convert D60 front Dually to non-dually?
I have a 1955 F600 grain hauler that I am converting to a truck for personal use. I was going to do a frame swap with a 1997 F350 4x4 dually but the task seems like more than I am capable of. Instead, I decided to swap axles and make new spring hangers.
My question. How hard is it to turn a D60 solid axle front dually hub into a non-dually hub axle? I don't need dually right now and just a 4 wheel truck would suit my needs for a long time before I consider turning this into a tow rig and need a dually.
I am thinking it's nothing more than a hub swap but before I tear it apart and shoot myself in the foot I thought I would ask for advice.
Advice?
Advice?
Received 3,107 Likes
on
I did see that the outer hub is bolted to the brake rotor assembly from the back side. I thought that would be a simple enough operation but, again, I am well known for burning water so I don't want to make assumptions. Another reason I thought it would be a hub assembly change is because even if I pulled the outer assembly off, I still have to have lug bolts and if the outer assembly bolts went thru the rotor, then are the holes too big for the lug bolts?
You know what they say about making assumptions. It makes an *** out of you and umption.
on
Coolness. When it get's a little warmer, I will make a nice long trip to the u pull it and do some scrounging. Thanks for all the heads up!
Yup. I got an idea for a low (not lowered, just low enough to get in the garage) riding 4 wheel driving truck. I don't do wheeling but I do drive in bad weather a lot and would like to pull a boat out of the water without worrying about traction. Other than that, it just seemed A LOT easier to just throw a 4x4 axle under it than mounting a ttb 1 ton front suspension. I expect to put the proper width wheels under it to make it look right even if I have to order a specific spacing or put spacers under it.
Either way, I get to bring an old truck back from rotting in the field and never seeing the road again (it never really did-farm truck, and those widowmaker wheels are never being used again either).
As Warhorse stated, you can use the hub assemblies from a TTB Dana 50 to convert your Dana 60 to SRW. This is very common for guys swapping D60s into other vehicles, as DRW units often sell much cheaper.
On another note, if you buy DRW rotors, you may need to drill the holes slightly larger to accept the shoulder of the lug stud.
You get it up and rollling and decide you need the SRW front hubs, I got an extra set I am sure we can work a fair deal on.
wyldstallyn73
12-05-2004 01:49 PM
