95 F-150 5.8 V8 loses power when wet.
Old 09-29-2016, 08:04 AM
ShadowHammer's Avatar
ShadowHammer
ShadowHammer is offline
What was wrong?
Did you ever out what was wrong?
Mine is doing the exact same thing.
Runs fine every day of the week unless it's raining or I hit a puddle, then it acts like it is going to sputter and die. I keep feathering the throttle but that doesn't work and then I stomp it, and it acts like it is going to die then revs to life and takes off. I have had to quit driving her in the rain.
Old 09-29-2016, 08:38 AM
Conanski's Avatar
Conanski
Conanski is online now
When I have experienced this problem with these trucks it has been because of a cracked ignition coil. Sometimes if you mist some water on the coil with a spray bottle while the engine is running you can reproduce the problem.
Old 09-30-2016, 01:32 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I had this type of problem once on my last truck and it was cracked spark plugs.
Old 09-30-2016, 08:17 AM
89scott's Avatar
89scott
89scott is offline
Bro that's a spark leak issue.
I learned about these going off-roading.. spent one night in the woods over a wet one.. sputtering.. didn't have enough power to k-turn or get back straight.
Trick is to pop the distributor cap off and spray WD-40. Next time off-roading.. I got the spudder right after huge puddle.. popped cap off WD-40.
The next day I took cap off and put a bead of clear silicone around the cap. 2 Sundays ago I ended up sinking the truck.. water up to the floor of the cab and didn't get no damn sputter at all.
The distributor is most likely the problem.. but check the spark plug wires for cracks or ARCs at night and check the coil.
Also.. try to re-create the problem on a clear day. Spray water from underneath at the distributor and try to run it up the street. If its spuddering, there's your issue.
Also reminds me.. grandmas van started doing this.. and it's raining today. Was supposed to fix it last week.. but clutch went out while sank.. Took chick's advice and left it running so water don't suck up tail pipe.. but that also burnt out the clutch in less than an hour.
str8racing
03-16-2008 06:18 PM
rpatrick
01-22-2007 03:02 PM
xg325
01-15-2005 04:58 AM
swenson
1978 - 1996 Big Bronco
11-07-2003 11:25 AM
knocturnal
06-23-2003 12:20 PM
Quick Reply: 95 F-150 5.8 V8 loses power when wet.
