Delphi glow plugs - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Delphi glow plugs
Old 12-20-2011, 09:29 PM
dyna dyna is offline
dyna is starting off with a positive reputation.
Delphi glow plugs
Are these ok to use,or should I stick with Motorcraft? I ordered a Stancor relay to replace my stock one,and thought I change the glow plugs also.
Old 12-20-2011, 09:38 PM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
Personally I'd stick with Motorcraft glowplugs.
This is where I got mine RockAuto Parts Catalog
Cost was about $83/shipped for all 8.
Old 12-20-2011, 09:56 PM
tennesseecoalroller0's Avatar
tennesseecoalroller0 tennesseecoalroller0 is offline
tennesseecoalroller0 is starting off with a positive reputation.
yes stick wil the stock motorcrafts iv heard that some of the others swell in the heads and you cant get them out aftwer a while
Old 12-20-2011, 10:20 PM
Motorcraft it is.
Old 12-21-2011, 01:05 AM
cutlass's Avatar
cutlass cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
Here's one more vote for the Motorcraft glow plugs ONLY!!!!!!!!!!! I had a glow plug tip on injector 8 fall get stuck in the head because of swelling and it was the only one in the engine that wasn't a Motorcraft. Somehow that tip was pushed down into the head farther than the position it sat in the head at the original installed depth. Was probably making contact with the piston at some point. It was an Autolight. That engine is since gone bye bye and I'm currently installing a reman. Ford 7.3.
I wanted to tear down the old engine to find the source of it's demise, but I had to return it ASAP for the purposes of getting my core deposit returned.
Old 12-21-2011, 03:15 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Give us a call if you have any questions.
Riffraff Diesel: Motorcraft Glowplugs
Glow plug question mrsvegan 1999 - 2003 7.3L Power Stroke Diesel 17 10-19-2013 08:26 PM
AIR INTAKE GLOWPLUG fancyvern 1999 - 2003 7.3L Power Stroke Diesel 3 09-26-2012 01:37 AM
Trouble Codes MustangMatt96GT 1994.5 - 1997 7.3L Power Stroke Diesel 37 02-09-2009 12:57 PM
Glow Plugs Attilak1 6.0L Power Stroke Diesel 5 03-05-2008 08:50 AM
glow plug module powerglyde1234 1999 - 2003 7.3L Power Stroke Diesel 1 11-07-2005 11:31 PM
Tags
73, 99, catalogue, delphi, dreck, glow, plug, plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
