Tires for 17.5 rims ? HELP - Ford Truck Enthusiasts Forums
Old 12-20-2011, 08:47 PM
John Wiseman's Avatar
John Wiseman John Wiseman is offline
John Wiseman is starting off with a positive reputation.
What do yall recommend I want to keep the stock rims on my 56 f250 They are 8 lug 17.5 x not sure of width. Are they going to be hard to find?
Old 12-20-2011, 09:34 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
The stock 17.5s are 5.25" wide. Both highway and traction grip threads are available from Universal Tire in a bias ply tread. USA made by Specialty Tire of America (STA). Keep in mind that your rims were not designed to run with radials. Budd would void the warranty if radials were used. Here's the link to the Universal catalog showing them. Stu
https://www.universaltire.com/truck-...truck.html?p=2
Old 12-21-2011, 03:54 AM
Thank You do they carry 16 ply I think that is what is on the truck now or will that be to stiff.
Old 12-21-2011, 04:13 AM
Yikes, 16 ply on an F-250! On a '56 F-250, new from the factory with 17.5s, there was a 6 ply option and an 8 ply option. The Universal Tire ad says theirs are 8 ply. That ought to cover it. Stu
Old 12-21-2011, 11:01 AM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
Hey Stu ..if he has 8 lug ..won't newer rims fit ..without all the frustration of overpriced tires ..and choices of everything out there ...and I was wondering if the spacer hub .(I don't know what they are called) he has would bolt on my hubs so I could fit 8 lug rims..sorry if this is a high jack ..but I ask to learn things ..
Old 12-21-2011, 11:23 AM
Quote:
Ken - Yes, regular 8 lug x 6.5" pattern 16s would work on the man's '56 F-250 if keeping the truck stock wasn't a priority. If keeping stock hub caps mattered that would limit options, but the ones with the correct "innie" hub cap nubs are out there too. And obviously 16" tires are everywhere.
Since it's an F-250, not F-350, his rear hubs have the 8 x 6.5" bolt pattern already. He doesn't have spacers like you're thinking. Stu
Old 12-21-2011, 11:39 AM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
I agree, a lot less choices on the 17.5's. I did an exhaustive search for something tall, like over 32". I found a toyo at 32.5, but they were about 300.00 or so, then shipping. And Kenjh, I can't swear to it, but I don't think you have rear spacers either. They look like it, but upon close inspection or disassembly, if I remember correctly they are one big massive hub with brake drum assembly that won't separate. I might be thinking of the front here, it's been a while..... Believe me, swapping to 8 lug is a major project(never mind a MH). The F250 guys have it made with the modern wheel thing, but let's face it, they're also stuck with that puny little 8' bed........
Old 12-21-2011, 01:20 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Four rough tread Yokahamas on the drive axle and Double Coin on the steer axle. About $1.150.00 a couple three years ago. The Double Coins took a bunch of weight.
R8x17.5s.
Old 12-21-2011, 01:35 PM
I thought that was funny 16 ply built like a Aircraft tire, This truck was a commercial work vehicle it has the original box with ladder rack built by a steel co in Ohio I believe
17.5 duelly rims fit a f350 ? Windsor1966 1961 - 1966 F-100 & Larger F-Series Trucks 22 11-12-2016 10:24 PM
17.5 single type 8 lug wheels (3) mrcman58 Ford Truck Parts for Sale 13 07-05-2016 02:40 AM
17.5 & 18in & 19.5 odd & end tires & rims mrcman58 Ford Truck Parts for Sale 2 12-31-2015 09:43 PM
17.5 x 5.25 wheels 8 lug 49 ford fire truck Ford Truck Parts for Sale 4 07-13-2015 11:40 AM
F350 8 lug rims - can I use these? Hudson High 1961 - 1966 F-100 & Larger F-Series Trucks 40 07-02-2015 10:20 AM
Tags
17, 175, 175rims, budd, f150, ford, lug, rims, steel, tire, tires, truck, vintage, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
