53 f100 6v battery cable hookups. - Ford Truck Enthusiasts Forums
Old 12-20-2011, 05:53 PM
chappys4life's Avatar
chappys4life chappys4life is offline
chappys4life is starting off with a positive reputation.
Does anyone have a diagram of the original battery cable hookups? I am more interested in the positive side and how it mounts. I am starting to wonder if my setup is wrong.
Old 12-20-2011, 08:06 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Being a 6 volt positive ground it should bolt to the frame close to the battery. Make sure you don't have paint or rust at that point...
Old 12-20-2011, 11:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It should be connected to the engine, like the intake manifold. From the engine, a separate strap should go to the frame and another to the cab. Those don't need to be that heavy (#12 is fine).
Old 12-21-2011, 07:12 PM
Dale Fairfax Dale Fairfax is offline
Dale Fairfax is starting off with a positive reputation.
Battery cable hookups.
That's what's shown in the parts catalog. The ground strap is part # FDE 14301-B and connects to one of the bolts which fasten the starter solenoid to the frame. There is another cable listed: FDA 14301-A which presumably is an engine to battery ground strap but it's unclear where it connects.
Quote:
Wire hookup ? Lonewolftx 1999 to 2016 Super Duty 7 10-22-2015 04:28 PM
Help! Need pic of throttle linkage on 87 351 Blue Rebel 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2015 11:11 PM
Speedometer not working Litlgar 1987 - 1996 F150 & Larger F-Series Trucks 3 04-19-2015 07:11 PM
Vacuum hookup for brake assist coppertales 1967 - 1972 F-100 & Larger F-Series Trucks 5 04-06-2015 02:23 PM
Dana 24 PTO Brian A57 Clutch, Transmission, Differential, Axle & Transfer Case 0 07-02-2003 08:11 PM
Tags
1952, 53, battery, cable, cables, connection, expedition, f1, f100, ford, grounding, hookups, locations, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
