Scangauge came today! what gauges do i need
Scangauge came today and cant wait to start playing with it and figure out what is really wrong with the truck!! But first must finish replacing ball joints!
What other gauges do i need ? Fuel pressure and EGT? am i missing any?
ISSPRO ev2 the way to go? Anyone know who has the best prices?
#####Fuel psi, EGT, low oil,######
most of the rest you will have available on your SGII.
Look around for a "G" force gauge would be fun! LOL
Let me know which way you go for Fuel and EGT. I have been putting those off, but maybe next tax season.
here ya go if some dont work just ask there is other codes to try
Go with ICP,IPR,EOT,BooST FICM MP,VGT for starters the boost on this list is off alittle hang on I will get the right boost code
TPA Throttle Position Actual (Degrees) TXD: 07E022093C RXF: 04624509063C RXD: 3010 MTH: 0064020000000 NAM: TPA
1CM
Cylinder #1 cumulative misfires TXD: 07E022160E RXF: 04620516060E RXD: 3010 MTH: 000100010000 NAM: 1CM
2CM
Cylinder #2 cumulative misfires TXD: 07E022160F RXF: 04620516060F RXD: 3010 MTH: 000100010000 NAM: 2CM
3CM
Cylinder #3 cumulative misfires TXD: 07E0221610 RXF: 046205160610 RXD: 3010 MTH: 000100010000 NAM: 3CM
4CM
Cylinder #4 cumulative misfires TXD: 07E0221611 RXF: 046205160611 RXD: 3010 MTH: 000100010000 NAM: 4CM
5CM
Cylinder #5 cumulative misfires TXD: 07E0221612 RXF: 046205160612 RXD: 3010 MTH: 000100010000 NAM: 5CM
6CM
Cylinder #6 cumulative misfires TXD: 07E0221613 RXF: 046205160613 RXD: 3010 MTH: 000100010000 NAM: 6CM
7CM
Cylinder #7 cumulative misfires TXD: 07E0221614 RXF: 046205160614 RXD: 3010 MTH: 000100010000 NAM: 7CM
8CM
Cylinder #8 cumulative misfires TXD: 07E0221615 RXF: 046205160615 RXD: 3010 MTH: 000100010000 NAM: 8CM
AP%
Accelerator Pedal Position (%) TXD: 07E02209D4 RXF: 0462050906D4 RXD: 3008 MTH: 000100020000 NAM: AP%
BAT
Battery Voltage (Volts) TXD: 07E0221172 RXF: 046205110672 RXD: 3008 MTH: 000100100000 NAM: BAT
BST
Boost (Untested) TXD: 686AF1010B RXF: 0441850B0000 RXD: 2808 MTH: 00910064FF88 NAM: BST
CVI
VREF (My notes indicate that this is the Calibration VTXD: 07E0221155 RXF: 046205110655 RXD: 3010 MTH: 000133330000 NAM: CVI
EBP
Exhaust Back Pressure TXD: 07E0221445 RXF: 046285140645 RXD: 3010 MTH: 001D00500000 NAM: EBP
EGR EGR Duty Cycle (Percent) TXD: 07E022166E RXF: 04620516066E RXD: 3010 MTH: 006440000000 NAM: EGR
EGV EGR Valve Position (Volts 0-5) TXD: 07E022167E RXF: 04620516067E RXD: 3010 MTH: 000133330000 NAM: EGV
EOT
Engine Oil Temp. TXD: 07E0221310 RXF: 046245130610 RXD: 3010 MTH: 00090005F05F ( UNAM: EOT
ERT Engine Run Time TXD: 07DF011F RXF: 0441051F RXD: 2810 MTH: 0001003C0000 NAM: ERT (Mi
ETP
EGR Throttle Position Control Signal TXD: 07E022096C RXF: 04620509066C RXD: 3010 MTH: 00647FFF0000 NAM: ETP
EVD
EGR Valve Position Desired (%) TXD: 07E02209D2 RXF: 0462050906D2 RXD: 3010 MTH: 00647FFF0000 NAM: EVD
EVM
EGR Valve Position Measured (%) TXD: 07E02209FE RXF: 0462050906FE RXD: 3010 MTH: 00647FFF0000 NAM: EVM
EVP
EGR Valve Position (mm) TXD: 07E022096A RXF: 04620509066A RXD: 3010 MTH: 000100010000 NAM: EVP
FI1
Fuel Injector #1 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3001 MTH: 000100010000 NAM: FI1
FI2
Fuel Injector #2 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3101 MTH: 000100010000 NAM: FI2
FI3
Fuel Injector #3 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3201 MTH: 000100010000 NAM: FI3
FI4
Fuel Injector #4 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3301 MTH: 000100010000 NAM: FI4
FI5
Fuel Injector #5 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3401 MTH: 000100010000 NAM: FI5
FI6
Fuel Injector #6 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3501 MTH: 000100010000 NAM: FI6
FI7
Fuel Injector #7 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3601 MTH: 000100010000 NAM: FI7
FI8
Fuel Injector #8 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3701 MTH: 000100010000 NAM: FI8
FL
Fuel Level TXD: 007E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 NAM: FL
FLP
FICM Logic Power (Volts) (Should be 12 volts) TXD: 07E02209CF RXF: 0462450906CF RXD: 3010 MTH: 0064010000000 NAM: FLP
FMP
FICM Main Power (Volts) (Should be 47-48) TXD: 07E02209D0 RXF: 0462450906D0 RXD: 3010 MTH: 0064010000000 NAM: FMP
FPW
Fuel Injector Pulse Width (microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW
FSS
Fan Speed Sensor (RPM) TXD: 07E022099F RXF: 04620509069F RXD: 3010 MTH: 000100040000 NAM: FSS
FVP
FICM Vehicle Power (Volts) (Should be 12 Volts) TXD: 07E02209CE RXF: 0462450906CE RXD: 3010 MTH: 0064010000000 NAM: FVP
HPR
Horse Power TXD: 00 RXF: 400080000000 RXD: 0000 MTH: 000A00240000 NAM: HPR
IA2
Intake Air Temperature 2 (Fahrenheit) TXD: 07E02216A8 RXF: 0462051606A8 RXD: 3010 MTH: 000100010000 NAM: IA2
ICP
Inj. Control Press. TXD: 07E0221446 RXF: 046205140646 RXD: 3010 MTH: 003900640000 NAM: ICP
IPR %IPR Duty Cycle TXD: 07E0221434 RXF: 046285140634 RXD: 3008 MTH: 0DCA03E8000A NAM: IPR %
ITM
Injector Timing Before Top Dead Center (Degrees) TXD: 07E02209CC RXF: 0462850906CC RXD: 3010 MTH: 000A00400000 NAM: ITM
MFD
Mass Fuel Desired TXD: 07E0221412 RXF: 046245140612 RXD: 3010 MTH: 006400100000 NAM: MFD
PSI
Manifold Absolute Pressure TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI
PSI Boost TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI
SYC
Crankshaft Position Sensor TXD: 07E02209CD RXF: 0462050906CD RXD: 3000 MTH: 000100010000 NAM: SYC
SYC
Camshaft & Crankshaft in sync (1 = in sync) (AlternTXD: 07E02209CD RXF: 0462050906CD RXD: 3001 MTH: 000100010000 NAM: SYC
TFT
Trans. Fluid Temp. TXD: 07E1221674 RXF: 046205160674 RXD: 3010 MTH:000100080000 NAM: TFT
TP1
Throttle Position 1 (Volts) TXD: 07E0220917 RXF: 046245090617 RXD: 3010 MTH: 0064040000000 NAM: TP1
TP2
Throttle Position 2 (Volts) TXD: 07E0220918 RXF: 046245090618 RXD: 3010 MTH: 0064040000000 NAM: TP2
I know Been thinking of composing a short list of just the main ones or Must have ones
dont worrey I was like WTF when I got mine to if you need help just ask Lots of guys can guild you threw it very popular now and Lots of folks have em
Ball joints so far not to bad right side ready to pull axle out! Is It a sign they are bad if u wiggle them and rusty water shoots out? Lol
Is it true auto meter gauges aren't much good? They are about half price of isspro
Thanks to everyone for all the help fte is amazing!!
My Autometer's have been in for 5+ years now and have been flawless.
Scangauge---ICP, IPR, FICM main voltage, ECT, and EOT. When you start adding it's easier to just add as many as possible and remember that they start at 24 and go down as you scroll through so if you alphabatize them put the "A's" on 24 and the "Z's" on 1. It makes it a LOT easier to quickly find what you want to see as you scroll through.
on
What gave you that impression? The price? Outside of my DashDAQ, I have 7 AutoMeter's in my truck and they haven't had a lick of trouble the 6.5 yrs (bought it in 05) that I've had the truck.
Yes lots of small victorys with BJ I would rather do another oil cooler
your right where my troubles started the threw bolts for the unit bearing were so rusted they formed threades and held solid in the knuckle
