Hub Bearing Torque Specs - Ford Truck Enthusiasts Forums
Old 12-20-2011, 12:06 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Got a '95 F-350 4x4 and I need the torque specs for the front hub bearings. A general procedure would be nice too. We're rebuilding the hubs and I'm kind of in a bind and I would appreciate a little help. I'm a SD guy so the OBS trucks are a bit new to me. I'm loving every minute of it, though. Thanks, guys!
Old 12-20-2011, 03:42 PM
dclack's Avatar
dclack dclack is offline
dclack has a good reputation on FTE.dclack has a good reputation on FTE.
For manual hubs:
Torque the inner nut to about 50 ft-lb while spinning the hub back and forth to seat the bearings; then back it off 1/4 turn. Adjust the inner nut as necessary to fit the dowel pin into the lock ring. Then the outter nut is torqued to around 120-150 ft-lb.
Auto hubs are basically the same but with a locking pin that slides between the nut and the spindle and no outer nut.
Old 12-24-2011, 10:17 PM
JonathanN's Avatar
Awesome! Worked perfectly... truck drives great! Reps!
Old 12-27-2011, 11:43 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Wrong thread. Sorry.
Old 01-04-2012, 04:45 PM
JonathanN's Avatar
Nice truck, though...
wheel bearing torque specs for 75 f100? NW 150 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-29-2012 07:39 PM
Torque specs for front wheel bearings?? Sixoh Ranger & B-Series 3 03-12-2011 06:56 PM
SRW / DRW Hub Bearing BadDogKuzz 1999 - 2003 7.3L Power Stroke Diesel 10 01-10-2011 06:06 AM
bearing locknut thatsrealnice 1973 - 1979 F-100 & Larger F-Series Trucks 100 03-18-2010 12:03 PM
Front Hub 4 Stud Torque Spec? PW_SD 1999 to 2016 Super Duty 4 02-09-2010 04:20 PM
Tags
03, 1994, 1999, 4x4, bearing, f150, ford, front, hub, nut, raner, ranger, specs, spindle, torq, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
