Seat height needed - Ford Truck Enthusiasts Forums
Seat height needed
Old 12-20-2011, 09:18 AM
sunbird79's Avatar
sunbird79 sunbird79 is offline
sunbird79 is starting off with a positive reputation.
Seat height needed
Trying to install a seat in my 1950 F4 I have a seat but no mounts. Can someone tell me how far it is in a stock truck from the floorboard to the top of the bottom part of the seat?
Old 12-20-2011, 11:52 AM
dawolverine's Avatar
dawolverine dawolverine is offline
dawolverine is starting off with a positive reputation.
Not sure on your truck, but when I fabbed up my seat mounts I test fitted my seats with various thickness wooden blocks first until I found the best driving height/position.
Old 12-20-2011, 12:09 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is online now
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
This shows some measurements for a 1950 F1 Panel - It should be the same for the F4 cab
http://s307.photobucket.com/albums/n...nt=48F1005.jpg
Old 12-20-2011, 05:28 PM
mtflat mtflat is online now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
The F4 truck is the same as the Panel: 15.5" from floor to crown of the seat cushion.
Old 12-21-2011, 11:12 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Quote:
I'm not sure if my F2 is the same but the measurement from the bottom of the seat to the bottom of the brackets is 5 1/2" front and rear. Here are some pictures. I ignored the shade tree lift that someone added to raise the seat and just gave you the bracket length:
60,000 transmission fluid change? awq134 2009 - 2014 F150 6 12-25-2014 02:50 PM
2015 F-450 Super Cab, Chassis Cab Lariat Rear Seat the_croz Ford Truck Parts for Sale 0 12-25-2014 11:58 AM
1964 F100 Bench Seat - '53-'55 Frame Fit? Brandon Koehl 1961 - 1966 F-100 & Larger F-Series Trucks 0 07-07-2014 04:29 PM
Cartouche Seat Upholstery Greg M-47 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 05-27-2012 09:21 AM
F250 Crew Cab Rear Power Point curt9999 1999 to 2016 Super Duty 3 05-26-2010 09:13 PM
Tags
height, seat, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
