I need a picture having trouble find one that will fit with a rear sump oil pan. The oil pan is a 215 oil pan with a rear sump I need to use it for clearance from the axel. Thanks
In the parts CD, it lists the same pan for 215 and 223, even tho the pump is different as Tinman notes. Remember those are the TRUCK pans. ALL 215 and 223 TRUCK pans (at least thru '56) are rear sump. Only the pickup assemblies are different between 223 and 215, and I would expect the 223 is easier to find.
Macs has some pictures, And if u type 223 oil pickup in google and go to images u see some. I honestly think I'm looking for something that doesn't exists but Ivknow people have ran in to this problem just hoping the right person reads this and could help.
there has to be some picture out there! 223 truck oil pickups! there gotta be someone that has one lying around. even if you think its not the right one i still would like to see pictures! thanks!
