Transfer case fluid??? - Ford Truck Enthusiasts Forums
Old 12-19-2011, 02:17 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
I forgot... Does the xfer case use ATF or an oil.
1990 f150
I've used ATF a number of times but I wanna make sure.
How many quarts does it take.
I think it needs changing because the xfer gets extremely hot on the hyway.
Or a bearing is going bad, but it's only got 60k on it and the driveshafts don't wiggle at the case. Hmmm
Old 12-19-2011, 02:30 PM
Youngblood45's Avatar
Youngblood45 Youngblood45 is offline
Youngblood45 is starting off with a positive reputation.
Per my Shopkey 1356 takes 2 qts mercon, 1345 takes 3.25 qts mercon.
Old 12-19-2011, 03:18 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
You can use any ATF.
Old 12-19-2011, 03:29 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
For the sake of simplicity, use the same ATF you're using on you tranny (that's if you have an auto, of course). Just for some others that might have that question in their minds: no, the tranny and transfer case don't share the fluid.
Old 12-19-2011, 04:02 PM
UNTAMND's Avatar
Quote:
Sweet. Thanks
Good idea about same fluid for both items. I should flush the ps fluid out sometime also. I hate carrying 5-6 different fluids for my diesel truck.
Old 12-19-2011, 09:13 PM
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
Shouldn't ps, tranny, and transfer case fluid all be the same?
Old 12-19-2011, 10:00 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
^ I'm not sure when Ford switched to Mercon in the power steering pump, but I know they specified Type F at least as recently as 94.
Old 12-21-2011, 12:19 PM
jas88's Avatar
It doesn't make any difference if the thing you are lubing doesn't have clutches like the trans does.
Old 12-21-2011, 12:22 PM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
Type F hasn't been used since the late 70's/early 80's. The M5OD manual tranny, along with most manual trannies in cars these days require ATF.
Old 12-21-2011, 04:59 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
Originally Posted by UNTAMND View Post
Sweet. Thanks
fyi,
in case you want to run mercon 5 in your E40D and ps pump.
MERCONŽ V Automatic Transmission and Power Steering Fluid
"Do not use in transfer cases where MERCONŽ ATF was previously recommended"
so looks like only the old school mercon should be used there still.
i used mobil1 atf synthetic in mine(t-case) cus it says it meets all mercon specs.i hope it wasn't a bad choice lol.
http://www.mobiloil.com/usa-english/...etic_atf.aspx#
edit,
oh your talking about a 2k f350 diesel truck.im not familiar with what the 4r100 (latter built e40d renamed) and t-case call for anyway.probably only mercon v for the trans,might both be mercon v anyway.seek correct section or owners manual.
Old 12-21-2011, 07:37 PM
UNTAMND's Avatar
I just threw in my superduty diesel as an exampl of all different fluids and needing to carry them all (diesel oil, mercon trans fluid, royal purple ps fluid, diesel antifreeze, dot5 brake fluid, methanol, fuel additive)
I was originally talkin about my 90 F-150. I'll never put mercon v in anything I own unless it came that way from factory. The 4r100 had mercon3 or regular mercon, Not mercon5. You can use either fluid in it, because it's backwards compatible. It's just too expensive for my liking.
I'll replace my ATF fluids all with the same brand ATF. It will make for topping off and replacing it very easy.
Old 12-22-2011, 07:33 AM
EPNCSU2006's Avatar
I was talking about the power steering fluid spec, not transmission. My 87 owners manual calls for type F in the power steering pump, and I'm pretty sure the 94 I took an engine from called for the same thing.
This makes sense too. I found another thread where someone said something similar:
http://www.ford-trucks.com/forums/16...ing-fluid.html
The motorcraft Mercon V page linked to by FORDF250HDXLT also says not to use in applications that specified Type F.
Old 12-22-2011, 08:42 AM
If I read right late model 4R70W and E40D that both used mercon can be changed to mercon V if you drain the torque converter and pan I think don't quote I read somewhere on here Ford had a service letter out that said this and it fixed some shifting issues
Old 12-22-2011, 09:15 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
^^^ correct,I did this to my 4r70w 3 years ago,no problems at all
married to divorced np205 chukar 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-27-2016 07:29 PM
Electric 4x4 question Bob Gervais 1987 - 1996 F150 & Larger F-Series Trucks 3 01-17-2013 05:14 PM
Transmission leak mudbug04 1999 - 2003 7.3L Power Stroke Diesel 11 09-27-2012 01:16 PM
BW transfer case output flange style jas88 1978 - 1996 Big Bronco 14 08-09-2010 12:38 PM
Anyone here use the x-fer case PTO? maverick1701 1994.5 - 1997 7.3L Power Stroke Diesel 15 07-15-2009 08:34 AM
Tags
06, 1990, 2010, 95, bronco, case, f150, f350, fluid, ford, fuild, oil, transfer, type, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
