My sons '97 Mustang Gt keeps blowing the fuse for the computer, I was told this meant the computer was bad, but it still does it with a new computer. Any thoughts what is causing it?
Found the book, it says that the Powertrain control module and the Constant control relay module are the only things on this fuse. I don't have a clue what those are or where they are???
The Powertrain control module is the "computer" that you've already replaced.
You SHOULD be able to find the "constant control relay module" in the electrical section of the manual.... (I don't know either. )
Terry, since you're the tech smartypants, will you post a link to this in our jackassery thread? Maybe Alan will see it and have a solution. My first thought was a wire shorting to ground. A wiggle test might be in order once the routing of the wires from the panel to the components is figured out.
Not sure about the '97's but 2000 and up have a small black box under the dash by the steering column. It's full of relays and the dinger for seat belts and such. If one of the relays hangs up or shorts out (pretty common) it can cause all kinds of strange problems. It took me two days to find a parasitic drain on an '02 Mustang. Turns out it was the relay box. It's also considered a body control module. I would try to unplug it and see if it starts.
Yes, that's the fuse, it blows as soon as the key is turned on. Before we replaced the pcm the fuel pump wouldn't even come on but the motor would crank. Now the fuel pump kicks on until the fuse blows then shuts off again and the motor cranks. I found the ccrm it is inside the fender apron. Pain to get to, will have to wait for the money to get a replacement and go from there.
Don't shotgun parts at it. Try unplugging the CCRM and see what happens when you turn the key on. You need to determine if it is an issue with a device or with the field wiring.
