Need Help with Sons '97 Mustang - Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
Old 12-19-2011, 12:50 PM
spedbugy's Avatar
spedbugy spedbugy is offline
spedbugy is starting off with a positive reputation.
My sons '97 Mustang Gt keeps blowing the fuse for the computer, I was told this meant the computer was bad, but it still does it with a new computer. Any thoughts what is causing it?
Old 12-19-2011, 12:53 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
What fuse number is blowing?
Old 12-19-2011, 01:08 PM
spedbugy's Avatar
Not sure of the number, it is the ecc fuse. Just found out the battery is bad? Idk if that is what is doing it?
Old 12-19-2011, 01:15 PM
MisterCMK's Avatar
Avid Winter Hater
A bad battery is not going to cause that fuse to pop. You need to get a wiring diagram and start looking for everything that is on that fuse.
Old 12-19-2011, 01:17 PM
tcbofade's Avatar
tcbofade tcbofade is offline
tcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputation
Do you have a manual for it?
Old 12-19-2011, 01:22 PM
spedbugy's Avatar
No, we don't have a manual for it.
Old 12-19-2011, 01:23 PM
tcbofade's Avatar
I believe that you can go to autozone.com, and access repair manuals through their website. (alldata?)
Old 12-19-2011, 02:17 PM
spedbugy's Avatar
Found the book, it says that the Powertrain control module and the Constant control relay module are the only things on this fuse. I don't have a clue what those are or where they are???
Old 12-19-2011, 02:27 PM
tcbofade's Avatar
Quote:
The Powertrain control module is the "computer" that you've already replaced.
You SHOULD be able to find the "constant control relay module" in the electrical section of the manual.... (I don't know either. )
Old 12-19-2011, 03:41 PM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
cyclopsblown34 has a good reputation on FTE.cyclopsblown34 has a good reputation on FTE.cyclopsblown34 has a good reputation on FTE.
Terry, since you're the tech smartypants, will you post a link to this in our jackassery thread? Maybe Alan will see it and have a solution. My first thought was a wire shorting to ground. A wiggle test might be in order once the routing of the wires from the panel to the components is figured out.
Old 12-19-2011, 03:44 PM
thomabb's Avatar
thomabb thomabb is online now
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
The owners manual will not list everything on that circuit. You will have to study the wiring diagrams to see what else is powered by that fuse.
Old 12-19-2011, 03:51 PM
earthquake68's Avatar
earthquake68 earthquake68 is online now
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Not sure about the '97's but 2000 and up have a small black box under the dash by the steering column. It's full of relays and the dinger for seat belts and such. If one of the relays hangs up or shorts out (pretty common) it can cause all kinds of strange problems. It took me two days to find a parasitic drain on an '02 Mustang. Turns out it was the relay box. It's also considered a body control module. I would try to unplug it and see if it starts.
Old 12-19-2011, 04:25 PM
MisterCMK's Avatar
Avid Winter Hater
It is a 20A fuse labelled EEC?
If so that goes to the CCRM Connector 192 pin 10 and pin 8 and also the PCM Connector 294 pin 55.
At the CCRM pins 8 and 10 look like they are connected to the PCM power relay.
Does the fuse blow as soon as you turn the key to on?
Old 12-19-2011, 04:48 PM
spedbugy's Avatar
Yes, that's the fuse, it blows as soon as the key is turned on. Before we replaced the pcm the fuel pump wouldn't even come on but the motor would crank. Now the fuel pump kicks on until the fuse blows then shuts off again and the motor cranks. I found the ccrm it is inside the fender apron. Pain to get to, will have to wait for the money to get a replacement and go from there.
Old 12-19-2011, 05:08 PM
MisterCMK's Avatar
Avid Winter Hater
Don't shotgun parts at it. Try unplugging the CCRM and see what happens when you turn the key on. You need to determine if it is an issue with a device or with the field wiring.
swap Dawgbite14 1997 - 2003 F150 2 10-14-2016 01:13 PM
Might buy a 97' F350 with 460 and MAF GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 1 04-16-2016 09:21 PM
Intake question 302 EFI performance JRS2 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 10-21-2015 07:01 PM
97 Lincoln 4.6 hot idle stall Old Rusty Modular V8 (4.6L, 5.4L) 0 03-04-2015 07:50 PM
which sensor for an A9P computer bigern6697 1987 - 1996 F150 & Larger F-Series Trucks 2 07-25-2011 06:37 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
94, 96, 97, blowing, blown, blows, computer, ecc, ecm, ecu, fuse, gt, location, mustang, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
