1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 f250 5.4L over heating problems
Old 12-19-2011, 09:07 AM
mantyfooser's Avatar
mantyfooser
mantyfooser is offline
I have a 2000 f250 Super Duty 4X4 with 249,000miles. The basic repairs have been general maintenance, fluids, brakes, tires, sparkplugs, thats it. I have had problems with the heater core clogging. I flushed many times, and replaced 4 times since 240,000miles. last week I lost heat, and starting having major overheating problems that have left the truck parked.
This is what I have tried, but nothing has worked:
-flush system with flush kit multiple times/ at a service center w/vaccum
-changed the thermostat two times ( wasn't sure if the new one was bad)
-new heater core again
-new water pump
-new radiator
My problem was truck would run fine, then the temp gauge would peg to H, engine sputter, so I shut off. Wait a few minutes turn on temp was fine, and truck was fine. I did everything to get air out. I noticed after running 10 to 15min I have extreme pressure in the overflow tank. I ran the truck without the thermostat and it does the same. Also did all steps to get air out
I have white smoke on start up, then stops after a minute. There is very greasy black residue in tailpipe, a little cream on the oil cap ( I have had that since 50,000 miles) no visible leaks (showing on the ground) I do consume antifreeze, lately a half gallon a week, some from boil over. I average 1000 miles a week, no trailer, do have tools and tool box, in bed
I think I may have a blown head gasket or cracked head. Does this sound right. Or am I overlooking something? Also if this would be this case would you try to tear down engine to troubleshoot to repair, or I found a replacement engine with 49,652miles 3 year warranty for $1800?? Either way both are a large project.
Thanks for any help
Old 12-19-2011, 05:11 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Sounds like a head gasket to me. Get a price on getting them done if its to much then I would look at the used engine.
Old 01-03-2013, 07:53 PM
Jeff Holmes's Avatar
Jeff Holmes
Jeff Holmes is offline
Hi, I have the same truck that is having the exact same problem. what did you ever come up with? my number is 909-890-8331 or my email address is racerjeff963@yahoo.com. Thanks
Old 01-03-2013, 08:24 PM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Hello Jeff Holmes and welcome to FTE.
I doubt you will get any response from the original poster in this thread. He posted once about 1 year ago and hasn't posted since.
It sounds like you also have a head gasket issue. The only way to tell for sure is an engine tear down, although a compression test might show a head gasket issue, if 2 adjacent cylinders are both down on compression. Another quick test is to have a mechanic use a tailpipe sniffer in the radiator (or overflow bottle) to detect the presence of combustion gases.
joshofalltrades
90
05-02-2015 01:03 AM
ArgoExpedition
1997 - 2003 F150
01-04-2015 03:38 PM
scottddove
18
02-25-2010 08:49 PM
pduryee
1978 - 1996 Big Bronco
10-23-2005 02:08 AM
mike L
09-26-2004 06:35 PM
Quick Reply: 2000 f250 5.4L over heating problems
