Oil dipstick tube gasket
Well I have spending a lot time under my truck taking things apart. I pulled turbo, down pipe, starter,IC tubes, intake spyder, air cleaner, battery tray and I am in the middle of pulling trans. Also pulling up pipes, valve covers and exhaust back pressure tube. It started out as needing to rebuild turbo and front seal on trans leaks and now it is like the snowball effect. One thing leads into another... you know as long as you are there type of thing.
To get to the point my dipstick tube is leaking at the gasket at the oil pan. And I was going to use Guzzler's repair kit. But I think I have bigger problems. Because the outer nut is tight but the fitting in pan is still loose. REAL SLOPPY I can feel it moving in and out. I think the piece in the pan is bad. Is that piece metal, do they warp ? Has anyone ever had this problem ? I just feel that if I go to replace the gaskets it isn't going to solve my problem.
Has anyone ever had any luck fixing this without pulling the pan to do it right? Any input would be apppreciated ?
What ever you do, do not over tighten it! You can warp the flange and ruin it. If this happens the oil pan would need removing. That's not fun! Guzzles kit works well. I'd give it a shot! Here is a clip of the warped flange that held my buddies rebuild up a day or two. Only thing we could come up with is it must of been leaking and someone tried tightening it before.
Check out this video on YouTube:
http://www.youtube.com/watch?v=AL78W...e_gdata_player
Sent from my iPhone
Sent from my iPhone
Thanks Bulla for posting the video. Well I think that piece is warped in mine too by the way it feels. So it looks like it is something I am going to have to live with for now !! I really don't want to pull the motor to replace a dipstick tube fitting. Another bright idea by Ford !!! Why couldn't they just weld the dipstick tube fitting in the pan ??
Saw this earlier from Strictly, what do you guys think? Looks pretty nice though a little rough on the ol' wallet.
Dipstick Adapter Repair Kit
Yes, the instructions state to insure that the factory adapter has hit the bottom of the sump of the oil pan. You do remove the o-ring though.
SkySkiJason
01-03-2011 12:36 PM
taylormade99
04-27-2006 05:29 PM
