6.0 check engine light help! - Ford Truck Enthusiasts Forums
Old 12-18-2011, 04:26 PM
brenthottle brenthottle is offline
brenthottle is starting off with a positive reputation.
My truck has been and still is running fine. But on my way home from church today my check engine light came on. Once I was able to get home I got my tuner out and checked the codes. Two came up po273 and po611. Can anyone tell me what they are and what I need to do to fix the problem? Christmas is almost here and I will be traveling with the truck and don't want to be stranded somewhere if its a major problem. Thanks
Old 12-18-2011, 04:59 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
P0273 I believe is a code either to do with circuit or contribution error. Which could mean FICM going out, wiring for the injector needing to be looked at, or injector going bad depending on what specifically that code is. That is, of course, if I'm remembering correctly that it is a cylinder code.
Old 12-18-2011, 05:01 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
P0273 is number 5 injector low circuit
P0611 Fuel Injection Control Module Performance
Old 12-18-2011, 05:41 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Go to the tech folder and perform the ficm test procedure. I have also seen low batteries cause these codes. Low batteries can cook an ficm.
Old 12-18-2011, 06:05 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
And keep this pdf file handy for future reference.
http://www.dieseltalk.com/support/DTC.pdf
Old 12-18-2011, 08:02 PM
Thanks for the responses! Will a low battery cause trouble in only one injector? I had my tuner in again and it showed the same codes again but listed the number 5 injector. I will check the batteries in the morning. But the truck turns over and starts just fine.
Old 12-19-2011, 02:53 AM
Dieselpop Dieselpop is offline
Dieselpop is gaining momentum as a positive member of FTE.
Old 12-19-2011, 01:47 PM
Thanks for all of your quick responses! I tested it late lastnight and it was the ficm going out of the truck. Unfourtanitly I don't have any time to wait for it to be rebuilt due to it being a work truck and the holidays coming. But I do have a few friends at my local dealership! So 700.00 part and installation I'm back up and running!
Diesel Pop thanks alot for the video you posted! It really helped me out alot. I was able to diagnose it right off and then tismorning when I went to the dealership to get the part I was ahead of the game by knowing what I needed. I just got lucky and they had a opening right then and could throw it on for me.
Old 12-19-2011, 03:32 PM
Glad it all worked out
pop
Old 12-19-2011, 04:19 PM
Deisel Pop for some reason the forum won't let me get to the message you sent me. I was able to read it from my email. I'm def interested. Please sent it to brent@hotcustomsigns.com or brenthottle@yahoo.com Thanks Alot!
Old 12-19-2011, 05:45 PM
tex25025's Avatar
Quote:
You a brush jockey brent?
Old 12-19-2011, 06:53 PM
Maxium4x4's Avatar
Good job Brent!
2003 Ranger--Check Engine Light bronco549 Ranger & B-Series 7 06-08-2011 11:09 PM
Diagnostic Codes RE injectors carmk 6.0L Power Stroke Diesel 1 06-21-2010 12:47 AM
All 8 injector circuits low 69cj 6.0L Power Stroke Diesel 22 04-26-2010 07:49 AM
CEL today, 8 DTC codes Kep4 6.0L Power Stroke Diesel 22 06-09-2009 05:33 PM
NEED HELP...error code PO156 & PO307 Schuby 1997 - 2003 F150 4 07-24-2008 12:54 PM
Tags
2003, 250, 5, 60, 60l, check, ckt, codes, dieisel, diesel, engine, f250, ford, injector, light, low, p0273, pull
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
