Happy 15 yo (now 16) son's 94 restoration w/PICS - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-19-2011, 05:50 PM
Boss08v10's Avatar
Boss08v10 Boss08v10 is offline
Boss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to behold
Tomorrow we are going to drop the truck off at his high school for him to show off and work on in power mechanics. The teacher is pretty fond of him both because he is mechanically inclined and because he taught with my sons grandfather for about 25 years. My late father in law taught welding and machining. They are going to put it in the air and run though it making list of priorities. This will help a lot having someone with his years of experience look it over for us.
He is out in the shed right now with a wire brush working on the chassis. Tomorrow we are going to order new shocks, coil springs and manuel lock outs. he already found a rear bumper, receiver hitch and stereo on craigs list.
  #32
Old 12-19-2011, 05:54 PM
justforkicks's Avatar
justforkicks justforkicks is offline
justforkicks is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Redneckfordf2502002 View Post
I am sure he will be very happy with that truck. I am 15 myself and own a 1988 F150 4x4 great truck. I ended up trading my 1987 Plymouth Reliant for this truck it was my dad's truck. I believe if you are to start out on a vehicle it needs to be a old run down ford truck that way you learn how to fix it and you know that truck very well. Mine we paid 400 for and it didn't run and was kinda beet up now it is great.
Trav
Couldn't agree more. My first truck I bought was when i was 14. it was an 87 Bronco II and i was able to drive it home. body was totally shot (paid $225 for it) and when you'd hit a bump, you could see the entire back half of the truck move around. panels were busted, body was rotten, door wouldn't shut half the time, but it ran and had 4wd so i didn't care! loved that truck. then i got my 77 f150 4x4 for free when i was 15 because it sat on blocks for 13 years, and the bronco ii wasn't so high on the list anymore. haha two great trucks right there. and nice ford there, Boss. why couldn't you be my dad haha jk
  #33
Old 12-19-2011, 06:26 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Quote:
Originally Posted by Boss08v10 View Post
Can you be more specific here as to the particular harness you are referring and its function?
Can't miss it, it is literally on the main front of the cylinder, where the front/rear brake lines go....Directly in front of the brake fluid reservoir...
  #34
Old 12-19-2011, 06:50 PM
Scndsin's Avatar
Scndsin Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
It should look like this:
If not, you need unplug it & take it to a dealer.
  #35
Old 12-19-2011, 08:09 PM
F350Kid238 F350Kid238 is offline
F350Kid238 has a good reputation on FTE.F350Kid238 has a good reputation on FTE.
is that wire problem just 150s or what cause my 350 doesnt have that
  #36
Old 12-19-2011, 08:50 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is online now
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
im 24 and the 95 is officially my first vehicle that I own 100% to my name, the beater my parents gave me was theres so i had no real decision in the matter (nor could I do what I wanted to it to fix it up my way) so yea I am happy with my Ford and I know he will be too! also I can't believe no one said this but get the boy on here so he can introduce his ride and him self, and show us some more ****...err pictures of the truck and maybe as he works to fix it...were all pic wh0res here anyways
on a side note, what year did ford officially make the recall part correct (ie did they change it so any thing from X year to 96 was fixed or what? i need to see if i need to be concerned, and the picture is not showing up for me for some reason...
  #37
Old 12-19-2011, 09:10 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Quote:
Yes you need it take it to any ford dealer have em put it on, recall and only takes a couple minutes to install it. You just won't be able to use cruise with it unplugged, truck will function normally in every other way until its corrected.
Unplug it, it can start your truck on fire even while sitting parked and shut off nobody around. Check for fluid in the switch, sure sign you where real close to loosing it if you see any.
The harness they add is fused, stops it from starting a fire.
  #38
Old 12-19-2011, 09:18 PM
Jaime74656's Avatar
Jim
ok I will check into my truck and that to see if its been done, how can I tell if its already been done or not? should there be noticeable difference? IE fuses? or will it look the same in the pic? (guessing thats the fused one?)
  #39
Old 12-19-2011, 09:34 PM
Thumper19's Avatar
Thumper19 Thumper19 is offline
Thumper19 is starting off with a positive reputation.
seeing how you said you guys plan to put new front coils on it. I have near mint Moog set of coils for an F150 with the 302. I'm sure they would work for his truck.
  #40
Old 12-19-2011, 09:49 PM
Sadly, I cannot give you anymore reps for a while...
  #41
Old 12-19-2011, 09:51 PM
Quote:
Yea you'll see the fuse holders, see it there in the left cable tie that's one of the fuses. My 95 F250 has two fuses in it however I only see one in his shot?
To install it the trucks harness connector is unplugged from the switch and connected to the premade fused harness, then the fused harness is plugged into the C/C cancel switch and cable tied in place.
You really should go look now if you're not sure, sure would hate to see you loose that one to fire.
If you see no fuse/s just unplug it.
You can check with any dealer to, have em run your VIN number and they'll be able to tell you if its effected (I bet it is) and if it was taken care of or not. That is if you're just not sure after looking at it.
  #42
Old 12-19-2011, 10:09 PM
Quote:
Thanks for the attempt, I run into that problem every time I try doing so too for just about everyone.
And while you're right here want to mention I did get your message I did notice it was there (always forget check for that sorta thing and completely miss them) any way wasn't ignoring ya just was not able to respond. Sits there with the little spinning thing going round and round but never actually goes through.
  #43
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
What springs are you guys ordering for it? If you mind me asking.
  #44
Old 12-19-2011, 10:17 PM
Ya know, I remember sending you A message....What it was about, hell if I know....LOL
  #45
Old 12-19-2011, 11:30 PM
Jaime74656's Avatar
Jim
yea Id hate to loose it too, thanks!
My '77 F150 build, AKA the saga of Bruce hivoltj 1973 - 1979 F-100 & Larger F-Series Trucks 74 06-09-2016 01:04 PM
New truck intro hivoltj 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-31-2012 12:48 PM
1" coil spacer I ordered ? Boss08v10 1987 - 1996 F150 & Larger F-Series Trucks 13 03-02-2012 04:23 PM
help to source license lens lamp Boss08v10 1987 - 1996 F150 & Larger F-Series Trucks 25 02-17-2012 06:11 AM
Glow Plug Switch: MOD /with pics richdawg 1994.5 - 1997 7.3L Power Stroke Diesel 18 10-27-2011 01:09 AM
Tags
150, 1998, 4x4, 68, 93, bg, class, e4od, f150, fixed, free, mom, pictures, powered, son, transmission, vbulletin, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
