F1 stock angle? - Page 2 - Ford Truck Enthusiasts Forums
F1 stock angle?
Old 12-19-2011, 01:44 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Got'em Dick, and thanks everyone for their input. The quicker I get the engine and tranny in this car, the quicker I can get to my F1. (the IH is in the engineering phase as well, and will be for quite awhile I'm sure)
FWIW, the car in stock form is zero degrees. The 2 degree difference means an adjustment in height at approx. 1 1/4". Or I could set the rear up to give the car a 2 degree rake, and angle the engine perches back 2 degrees to compensate.
http://www.cleavebooks.co.uk/scol/calrtri.htm
Old 12-19-2011, 06:09 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Quote:
Originally Posted by havi View Post
.... if the car has a 2 degree rake, all is good. If not, then shims may be needed.
Along the lines of rake and shims, maybe you can help me Havi.
When I took the front axle out of my truck it had no shims and when I took my parts truck axle apart it had a shim on one side.
Now that I am putting it back together, I don't know if I need 2 degree or 4 degree shims. From what you are saying it sounds like I may not need any shims on the front axle due to my big/little tire combo that will result in a "rubber rake"? What do you think?
Old 12-19-2011, 06:39 PM
havi's Avatar
All things being stock, if there are taller tires on back, your caster will become more negative, though not by much, I wouldn't think. This would call for a need of shims. what degree, I dunno.
Old 12-19-2011, 06:43 PM
Thanks! I suppose I will find out when I test drive it.
Old 12-20-2011, 07:21 PM
havi's Avatar
BPD, I jacked up the rear of my car to achieve a 2 degree rake from zero, and the rear tires were off the ground about 2.5". The wheelbase is 115.5" so it's fairly close to an F1. It has 175/70R13's all around. Hope this gives you some more insight into your pickup.
Stock F100 1956 rear axel pinon angle anyone? jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-08-2014 08:23 AM
Rake angle question for those with a MII Doc 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-24-2012 05:31 PM
Front axle pinion angle seems wrong? glosol 1973 - 1979 F-100 & Larger F-Series Trucks 15 05-22-2011 06:33 PM
Universal joints ...pinion angles 52 panel 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 02-15-2011 01:54 PM
pinion angle on 75 f250 Highboy76 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-26-2003 04:13 PM
Tags
34, 62, angle, caster, castor, econoline, f1, ford, shims, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
