Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 12-18-2011, 07:44 AM
mark63uni's Avatar
mark63uni mark63uni is offline
Garage is empty, add now
mark63uni is starting off with a positive reputation.
converting to 4X4?
I found a short box close to home here for a decent price, I was wondering if anyone has changed one of these over to 4 wheel drive? And whats the best way to do it, get the drive train and fabricate or put the body on another frame.. any ideas what it might fit on, bronco?
  #2 (permalink)
Old 12-18-2011, 11:22 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Easiest way is to place a front drive axle on 4x4 leaf springs and lift the rear springs. Add a modern motor and trans/T-case on custom mounts and some drive shafts.
Adding a new fame would not give you any benefits over the frame you all ready have. The frame width is basically the same from 61 to 96. You can use a 44 from a 250 up to 77.5 and convert the hubs over to five lug. A F100 axle 66 and up will be a coil spring type and not conductive to a leaf spring swap.
Garbz
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #3 (permalink)
Old 12-19-2011, 08:41 AM
mark63uni's Avatar
awesome, thanks
  #4 (permalink)
Old 12-20-2011, 01:42 PM
Zip's Avatar
Zip Zip is offline
BC Chapter LDR
1979 Ford Bronco
My Garage
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
My 65 was converted to a 4x4.
Click the image to open in full size.
__________________
Chris,#12 BS'er/Official Slackmaster #7/AVIDEST WINTER HATER
BC Chapter Member/Leader
JOIN THE BC CHAPTER HERE
Tags
1963ford, 4x4, 63, 64, box, classic, conversion, converting, drive, f100, ford, frame, short, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
