Looked at another truck
Old 12-18-2011, 05:53 AM
3414's Avatar
3414
3414 is offline
Well, I went to look at another parts truck yesterday a little more than 2 hours from home. From what I could see (could not get inside due to frozen door latches) it is a 1960 F750. I made a deal on what I want, but there are several interesting things on this truck - power steering and air brakes. It also has a 2 speed rear. Mechanical parts look good, but there is not much left of the body due to rust. If anyone wants info on this, PM me. From what I have seen, power steering was not too common on these, and I do not know if it can be adapted to the F500 and F600 trucks.
Old 12-18-2011, 02:49 PM
tbirdscott's Avatar
tbirdscott
tbirdscott is offline
Does it have the big job scoop on the hood?
Old 12-18-2011, 05:59 PM
3414's Avatar
3414
3414 is offline
No scoop. I have only seen them on 850 and up. But if someone is looking for the power steering, the parts look good. But the body is pretty rusty.
Old 12-18-2011, 06:17 PM
spurredon's Avatar
spurredon
spurredon is offline
Speaking of power steering, my '60 F100 has the steering box and column out of a '59 F500. The box itself is perhaps twenty percent bigger than that of the F100. With the total rebuild of the front end and the mechanical advantage of larger gears, there isn't really a need for additional power steering. That thing really turns smooth and easy. Of course you can not one finger it but I get by. I did have to drill new holes in the frame to mount it as the foot print was different. I also had to make a longer tab to hold the clutch return spring out a little farther from the frame to get around it. So it would be worth grabbing the steering box if you could. Someone could use it.
Old 12-21-2011, 04:07 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
um.. definitely pick up the emblems that say F750!!! I cant find the inserts anywhere. Also the mirror brackets-i need those too as long as they are the west coast big-rig style.
Mirrors should look like this.
Old 12-21-2011, 04:12 AM
78_f800crewcab4x4
there is a scoop on ebay right now, about 100 bucks at the moment, look up f850
zombiefied 247
11-30-2012 12:55 PM
mkoser
11-05-2009 06:18 AM
sc63uni
08-20-2007 02:49 PM
FirstTry
04-11-2006 01:04 PM
22mill
05-23-2002 06:50 AM
Quick Reply: Looked at another truck
