Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-18-2011, 05:53 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
Looked at another truck
Well, I went to look at another parts truck yesterday a little more than 2 hours from home. From what I could see (could not get inside due to frozen door latches) it is a 1960 F750. I made a deal on what I want, but there are several interesting things on this truck - power steering and air brakes. It also has a 2 speed rear. Mechanical parts look good, but there is not much left of the body due to rust. If anyone wants info on this, PM me. From what I have seen, power steering was not too common on these, and I do not know if it can be adapted to the F500 and F600 trucks.
  #2 (permalink)
Old 12-18-2011, 02:49 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
Garage is empty, add now
tbirdscott is starting off with a positive reputation.
Does it have the big job scoop on the hood?
__________________
1960 Comet mostly stock, summer DD
1979 Ranchero/Thunderbird 'Thunchero' 390 or 460 powered in the future...
1980-82 thunderbirds everywhere you look
1994 F350 IDI turbo getting a 1959 Mercury body transplant
1994.5 F250 PSD, 5spd 4" rancho on 35's
  #3 (permalink)
Old 12-18-2011, 05:59 PM
1960 Ford F-600
My Garage
No scoop. I have only seen them on 850 and up. But if someone is looking for the power steering, the parts look good. But the body is pretty rusty.
  #4 (permalink)
Old 12-18-2011, 06:17 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Speaking of power steering, my '60 F100 has the steering box and column out of a '59 F500. The box itself is perhaps twenty percent bigger than that of the F100. With the total rebuild of the front end and the mechanical advantage of larger gears, there isn't really a need for additional power steering. That thing really turns smooth and easy. Of course you can not one finger it but I get by. I did have to drill new holes in the frame to mount it as the foot print was different. I also had to make a longer tab to hold the clutch return spring out a little farther from the frame to get around it. So it would be worth grabbing the steering box if you could. Someone could use it.
  #5 (permalink)
Old 12-21-2011, 04:07 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is offline
78_f800crewcab4x4 has a very good reputation on FTE.78_f800crewcab4x4 has a very good reputation on FTE.78_f800crewcab4x4 has a very good reputation on FTE.78_f800crewcab4x4 has a very good reputation on FTE.
um.. definitely pick up the emblems that say F750!!! I cant find the inserts anywhere. Also the mirror brackets-i need those too as long as they are the west coast big-rig style.
Click the image to open in full size.
Mirrors should look like this.
__________________
1960 Super Duty Crew Cab, 1978 F800 SuperBronco, 2002 Excursion.
Looking for 57-60 Styleside bed, 73-79 Big truck fender extension.
  #6 (permalink)
Old 12-21-2011, 04:12 AM
there is a scoop on ebay right now, about 100 bucks at the moment, look up f850
__________________
Tags
1960, f500, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
