F series tow hitches - let's see them - Ford Truck Enthusiasts Forums
Old 12-18-2011, 02:26 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
G'day all, I want to draw up some plans to build a new tow hitch for my 49 F3. The one on there at the moment is very lightweight and basic. I want to use the truck to tow around a speed boat and possibly a car trailer occasionally. I'd like to see some pics of other peoples set up to get some design ideas.
Thanks
Old 12-18-2011, 11:22 AM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
I don't have any pics as I'm still doing my research... But I've toyed around with this idea myself... and there are some things that I've been working on...
  1. Will you going to using the stock fuel tank or relocating it under the bed?
  2. Have you thought about running a rear bumper, roll pan or nothing?
  3. Is it going to be a receiver hitch or a permanent knee knocker, and it its a receiver is it going to be hidden?
  4. Are you adding or already added disk brakes to you f3?
  5. Since you said your wanting to tow a car hauler, have you thought about a electric trailer brakes?
All are very important thing to think about prior starting your build.
Last edited by Moe Craig; 12-18-2011 at 12:08 PM. Reason: Just saw that you have a flatbed and staying with it
Old 12-18-2011, 12:31 PM
I'll be using the stock tank, it appears to be in great condition so don't see a reason to change it. As it will have a bed on it I won't be running a bumper or pan. I'll make it a receiver hitch for the neat look. No discs but will be looking for an F250 diff to swap in to give better highway cruising and let me get rid of the widow makers. Won't be going electric brakes, the car hauler won't have anything heavy on it, mainly 1920s cars and mechanical or hydraulic brakes will work just fine.
Old 12-18-2011, 12:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
IMO electric brakes have reached a level of sophistication that no hydraulic system can match. The controllers have proportional deceleration sensors that make the difference. But that's just a wiring issue for down the road.
Around here, there are shops that do almost nothing but hitches for commercial trucks, either totally custom or adapting standard pieces. I'm not talking about U-Haul, these guys do the big stuff. I would take it to that kind of place and at least see what they recommend. But a lot depends on final ride height, so I would wait until you have that established.
Old 12-18-2011, 12:47 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I have no knowledge of the Aussie laws as they apply to towed vehicle brakes but here in the US most places make it illegal to tow as much weight as you are suggesting without trailer brakes. I will guarantee you that the first time you have to make a panic stop without trailer brakes you'll install the brakes right after you clean your pants.
The added picture is the hitch on my '56 F350
Old 12-18-2011, 01:52 PM
I'm not for a second suggesting towing without trailer brakes, just using mechical or hydraulic trailer brakes rather than electric. I agree electric brakes are great but not many trailers here have them.
Old 12-18-2011, 03:26 PM
Moe Craig's Avatar
Keep us informed how it goes... I don't know what the roads or traffic is over there but here in Mesa, AZ you wouldn't get me to tow anything without disk breaks and or a trailer with electric brakes on it.... I've personally have had a car trailer attached to my DD with disk brakes and the trailer was enough to push me into a intersection with a mild wet road... Just my 2 cents... But would love to see what you come up with...
Old 12-18-2011, 06:48 PM
jniolon's Avatar
jniolon jniolon is online now
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
ac
here's a thread on research I did for a '53 hidden hitch... might be of interest to you
john
http://www.ford-trucks.com/forums/11...r-hitches.html
Old 12-18-2011, 10:25 PM
Doraville's Avatar
Doraville Doraville is offline
Doraville is gaining momentum as a positive member of FTE.
Here is a post from another thread that documents what we did on my truck. I wanted my hitch receiver to be as hidden a possible. We wound up building an "inner bumper" using 4" channel steel. I'm happy with the way it turned out.
-DV
Old 12-19-2011, 01:43 AM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
I just took a unit and cut the ends off and fited it in the web of the frame and welded some bolt on plates and hide the receiver behide the flipdown tag. you can't see it at all for the rollpan . I pulled my boat the other day and old yeller did good. Got one on the green truck also i'll take a pic. 2mor.
Old 12-19-2011, 09:54 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Just happened to take a picture of the hitch on my 50 F4. Not a receiver hitch but typical of farm trucks.
Old 12-20-2011, 03:59 AM
Now that is one beefy hitch, pretty similar to what you see on farms out here too. The white stuff on the ground looks a bit alien though.......
Raytasch, I love the Ford embossed into the rear of your tray, I may have to steal that idea!
Old 12-20-2011, 05:38 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
When you're done....I'd like to see a pic of the speedboat in tow behind the F3!
Old 12-21-2011, 01:19 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Quote:
That's a factory Ford flatbed (tray).
Old 12-21-2011, 02:34 AM
Quote:
You'll be waiting a while... the boat is a whole other project!
Gooseneck hitch kit ball size lhansman 6.7L Power Stroke Diesel 10 02-12-2015 12:47 AM
front hitch - can a rear hitch be moved to front speakerfritz 1999 to 2016 Super Duty 1 07-03-2014 11:19 AM
Hensley Arrow travel trailer anti-sway Hitch X_Hemi_Guy Ford Truck Parts for Sale 1 09-11-2012 10:25 PM
Hitches, Suggestions Needed aj197816134 1994.5 - 1997 7.3L Power Stroke Diesel 6 03-06-2011 11:10 AM
92 F-150 Bumper Hitch Towing cap??? Emrock 1987 - 1996 F150 & Larger F-Series Trucks 3 01-21-2005 11:39 AM
Tags
california, hitch, law, tow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
