dyno day v1
Old 08-29-2012, 05:01 PM
Ford F834's Avatar
Ford F834
Ford F834 is offline
Originally Posted by 91dirtydiesel
here ya go
Is the "J2" cam the same thing as NMB2's "turbo" cam or are they different? Ordered the Turbo Cam, interested if this graph reflects its properties. Also, if the turbo cam eliminates valve overlap and increases boost, did the two trucks have similar turbos on them? Might the choice of cam be influenced by which turbo is being used?
  #32
Old 08-29-2012, 05:26 PM
NMB2's Avatar
NMB2
NMB2 is offline
they are one in the same.
  #33
Old 08-29-2012, 07:52 PM
Ford F834's Avatar
Ford F834
Thanks. That's helpful. Starting to re-think my gearing choice, as 4.10's with ZF-5 speed AND Gear Vendor overdrive would put me at 2.46:1 final output... I'd be turning exactly 2,000 rpm at 75 mph which is a bit out of the cam's peak torque range. Still trying to work out a swap with a co-worker for his D60/10.25 axle set with 3.55's. If I ditched the GV I would have 2.73:1 and be turning 2,220 rpm at 75 mph in 5th. Seems better for that cam. With the other set-up I can see needing to turn off the OD a lot and letting it scream at 3.16:1... well, I've been living with T19 + GV = 3.20:1 and it feels like it wants another gear, even NA. Not screaming like 4.10's with no OD but still...
  #34
Old 08-30-2012, 01:01 AM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
Ok.... Preliminary numbers off the top of my head, im sure graphs will be posted by tomorrow, but here is the list...
RacinNdrummin- 342whp/759wtq
91dirtydiesel- 202whp/442wtq
lilredsled-227whp/462wtq
NMB2- 354whp/665wtq (Justin might have to correct tq, Thats the number I remember, might not be accurate)
Ill elaborate more in my thread about my truck, but I did manage to gain 50hp in tuning on the dyno....
To the guys that were there, feel free to correct any mistakes I made...
  #35
Old 08-30-2012, 01:07 AM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
this was my set up previously:
4.10 gears, 38" tires, ATS turbo, 4" intake with AEM filter, 3" DP, 5" exhaust, NA ip maxxed out
current set up:
4.10 gears, 35" tires, ATS turbo, PSD intercooler, 3" charge pipes, R&D intake manifold, 4" intake with AEM filter, 3" DP, 4" exhaust, Turbo ip maxed out
First setup made 202/419 @ 17 psi @ 1200egt
Now it made 202/442 @ 13psi @1000egt.....pump upgrade time!
Still can't believe lilredsled held 20psi and 1400egt without blowing up!!! LOL
  #36
Old 08-30-2012, 01:23 AM
NMB2's Avatar
NMB2
NMB2 is offline
365 was my highest HP run... don't know the torque that went with it. Eric said when he was printing out that it didn't save or something.
On paper I have 356/676
  #37
Old 08-30-2012, 01:48 AM
NMB2's Avatar
NMB2
NMB2 is offline
Just the videos I have uploaded for now....as you can see, my engine is using everything this DB4 can put out...
20120829 210306 - YouTube
6.9 IDI Dyno - YouTube
  #38
Old 08-30-2012, 02:01 AM
RacinNdrummin
Eric said that the 365 run was the computer/dyno flaking out, much like my 806tq run... 676wtq sounds right now that I think about it...
Enjoying the Crown?
  #39
Old 08-30-2012, 02:06 AM
NMB2's Avatar
NMB2
NMB2 is offline
Enjoying the Crown?
Oh ok, I didn't hear him say that. I thought he said it was on the sweep test and didn't save or something.....
Yeah, thanks for the crown.
By the way.... I was happy until someone brought competition to the table. Watching those videos my truck is burning every last drop of diesel being injected, and I have no bottle necks gives me a mild hard on...... Might be time to increase some roller to roller
  #40
Old 08-30-2012, 02:21 AM
RacinNdrummin
Dew it br0, these IDI guys love to see the competition!
  #41
Old 08-30-2012, 09:50 PM
NMB2's Avatar
NMB2
NMB2 is offline
  #42
Old 08-30-2012, 09:55 PM
therifleman556's Avatar
therifleman556
therifleman556 is offline
so as some of you may know there was some built up idis ( nmb2 and racin) here is how things went today
Dyno day 12/17/2011 Erics automotive, Enumclaw, WA
Name/Truck/(WHP/WTQ@Peak Boost)/Mods
NMB2 (out)
Doug/ 2005 5.9 6-spd/(311/589@??? boost)/Thru Muffler.
RacinNdrummin/ 1988 7.3 5-spd/(235/477@18 <ACRONYM title="lbs per sq inch">psi</ACRONYM>)/S362,DPS turbo cal,J2 CAM,IC'd
Typ4/ 1991 F350 5-spd/(218/461@14psi)/60-1 wheel,CAI,typ4 cam, IC'd
91dirtydiesel/ 1991 F350 5-spd/(202/419@17psi)/ATS turbo,Intake tube & filter,5" exhaust
Totalled/ 1973 F350 390 Auto/(203/293@N/A)/4bbl,intake,RV cam,headers
Chris Tongue/ 1985 Chev 6.5 Auto/(138/285@12psi)/Banks Turbo Kit
Papastruck/ 1986 F350 6.9 auto/(123/384@10psi)/Banks Turbo,Baby Moose,Exhaust
Pirate4x4 guy/ 1992 F250 7.3 5-spd/(123/283@N/A) Dead Stock
so needless to say there will be another
pics and vids coming
Was there something wrong with this guy's truck or do 6.5s in fact suck that bad?
  #43
Old 08-30-2012, 10:00 PM
NMB2's Avatar
NMB2
NMB2 is offline
this has my runs on it, but with a 1000-7000rpm grid it makes the curve small and funny looking
Here is a run with a normal sided grid
  #44
Old 08-30-2012, 10:47 PM
91dirtydiesel
LOL guess they suck
  #45
Old 08-31-2012, 01:02 AM
NMB2's Avatar
NMB2
NMB2 is offline
Quick Reply: dyno day v1
