SuperDuty93 Mod/build thread
Old 12-18-2011, 01:55 AM
73f250highboy's Avatar
73f250highboy
73f250highboy is offline
Holey cow!! There's no way.
Old 12-19-2011, 01:49 AM
SuperDuty93's Avatar
SuperDuty93
SuperDuty93 is offline
Ya i found it hard to believe. But its true....
Ok as of today i drove it around and its runs awsome! And i had a little fun once it got dark. Check it out. Old 60's FORD (I know the owner)
Old 12-19-2011, 09:50 PM
SuperDuty93
Ok 73f250highboy, so the gas tank is LxWxH (30"x26"x16") but it has a staircase affect at the back so a cross bar can go over it so it goes from 16" tall to 10" tall. The whole thing is hidden behind the hitch
Old 12-19-2011, 09:56 PM
73f250highboy
Thanks! Id like to see some pictures of it in there if thats possible?
Old 12-19-2011, 10:05 PM
SuperDuty93
Give me a sec to check my phone. I think i have 1 or 2 of it mounted in there.
Old 12-19-2011, 10:10 PM
SuperDuty93
Here ya go.
IDK WHY THOSE 2 ARE SO SMALL??????
Old 12-21-2011, 01:13 AM
SuperDuty93
So im working on driveshafts and diff stuff. Does anyone know the best way to check to make sure you have fluid in the diffs?
Old 12-21-2011, 11:33 AM
wyckedcombo17's Avatar
wyckedcombo17
wyckedcombo17 is offline
If ya got a D60 pull the top fill plug and see if any lube comes out. If not stick your fanger in there and see how low it is. I don't remember if the 9" have a fill plug or not.
Old 12-21-2011, 03:31 PM
73FordF100's Avatar
73FordF100
73FordF100 is offline
Awesome truck! I'm watching this thread!
Old 12-26-2011, 12:36 AM
wyollie's Avatar
wyollie
wyollie is offline
Same thing with the 9"- just pull the top plug.
Old 12-27-2011, 11:16 PM
SuperDuty93
I was going to video alot more but battery was dying and i ran outa space on the camera
But this is what i got.
74 F250 - YouTube
Old 12-28-2011, 08:16 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
Nice truck!
As far as the diff's go, specs say full is up to 1/4" below the hole. Any lower and you should top it off. (80w90 gear oil unless it's limited slip, posi, etc. Then you'll need some additive)
  #28
Old 01-15-2012, 01:01 AM
SuperDuty93
Ok here we go with the latest and not so great but not to bad...
Took the carpet up to check floorboards because from under the driver side there are alot of self taping screws sticking out. Im like WTF is this???? Figured it out after pulling the carpet up. Would someone like to explain this to me. WHY!
Someone put a piece of sheet metal over the floorboard for no apparent reason. I took all the screws out and there were no hole in the floor board. So wierd. Alot of rust but no major stuff so i treated it with this stuff called THE RUST DOCTOR.
Pass side was clean for the most part.
Also saw this going down the freeway. I was in my Bronco
  #29
Old 02-29-2012, 08:06 PM
SuperDuty93
Ok so i bent another pushrod This is starting to really PO me. Paid 600-800 to have the heads done and and one of the valves stuck or something. And i also had a new lifter collapse So i demanded the head place pay me to remove the heads again and they will be paying to fix it a 2nd time.... In the meatime i have new interior LED's installed (ill post a video soon) and have a pile of parts to install while i wait for the heads to get back.
Here are all the new parts minus a bumper, strobe lights, new tail lights, hi lift jack(ordering that soon) and a few little odds and ends.
Dual battery set up
Anyone know if these lights are any good?
Here are the interior lights. I currently have them in color change mode. (click on link if video does not play)
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1083.photobucket.c om%2Falbums%2Fj386%2FSuperDuty93%2F0229121812a.mp4 ">
http://s1083.photobucket.com/albums/...229121812a.mp4
  #30
Old 04-06-2012, 10:22 PM
SuperDuty93
So i had nothing better to do today and i found a can of engine paint. I never knew a can of paint and a pointer finger could be so dangerous haha. So anyway i did a little detailing. (the blue is alot darker than in the pics)
Quick Reply: SuperDuty93 Mod/build thread
