gas tank
For behind the axle if you want to go that way a tank for the 1984 Bronco II it will fit in. 23 gallons. The reason I used the 84 is no fuel pump in tank. 1985 has electric pump in tank. Just remove the bed, grind rivets from rear cross member and slide it ahead a few inches and bolt it back in. Add another to the rear for bolting the straps to. I got the off road guard at the local auto wrecking yard.
E4TZ-9275-B .. 1984 Bronco II Fuel Tank Sending Unit / Obsolete
18 available NOS from Ford Dealers/obsolete parts vendors.
E5TZ-9275-D .. 1985 Bronco II Fuel Tank Sending Unit / Obsolete
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
Etone
03-16-2017 08:27 AM
H311RA151N
35
01-10-2016 04:34 PM
Jesters Court
01-04-2010 08:50 PM
parks911
02-01-2004 02:39 PM
