1993 ford f 250 supercap 2x4 with a 7.3dsi diesel
Old 12-17-2011, 07:29 PM
jakegreen81's Avatar
jakegreen81
jakegreen81 is offline
I have a 1993 ford f250 with a 7.3 dsi diesel. run fine up until yesterday. i went out in the morning to go to work to. i put the key in the ignition without turning it and the starter activated.
At this point i have replaced the fender wall solenoid as well as the solenoid on the starter took the ignition switch out from under the dash, took it to the part store they told me it didn't smell burnt therefore it was good i did not buy the new ignition switch however, am at a loss at this point for at least now the starter don't activate until i turn the key to wait for the glow plugs. At a loss in Michigan, any help would be appreciated.
Old 12-17-2011, 08:06 PM
jakegreen81
i have had this on the charger now for a while i am just at a frustrated state of mine having problems finding a wiring diagram for this truck any suggestions
Old 12-17-2011, 08:18 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
Find another parts store, those guys are idiots. Ignition switches wear out from years of having a key inserted and removed, I've never seen one "burn up". It's possible that its somehow getting stuck in the "start" position. I'm assuming you mean "7.3 IDI diesel" btw.
Old 12-17-2011, 08:27 PM
jakegreen81
rite it is a 7.3 idi diesel i was referring to the ignition control module under the dash. i have not tried to replace the ignition switch itself yet however, i am under the understanding there is actually no power going to the ignition switch it self until it activates the ignition control module am i wrong in this assumption.
Old 12-17-2011, 09:23 PM
Phy's Avatar
Phy
Phy is offline
The ignition cylinder is what the key goes into. It is connected by linkage to the actual ignition switch, located further down the steering column. It has a large electrical connector on it...
Old 12-18-2011, 07:57 AM
bashby's Avatar
bashby
bashby is offline
correct
Autozone.com has some wiring diagrams, register and look under repair info
incorrect, other than the idiots at the parts store part
incorrect. You probably have a bad ignition switch or the linkage that activates it is broken.
Old 12-18-2011, 09:46 AM
264WSM's Avatar
264WSM
264WSM is offline
I just had the opposite problem. Turn the key all the way to the start position and it would only glow the plugs. I jumpered the fender mounted solenoid to get it started.
After a week of jumpering it, it was time to pull the steering column apart. Turned out to be the cast aluminum linkage in the column was broken.
66f-100
10-05-2011 04:29 AM
datsun147
05-10-2011 03:01 PM
Olbeater
11-01-2010 05:31 PM
Rayray1102
09-08-2009 06:42 PM
Murray1
01-29-2008 11:06 AM
Quick Reply: 1993 ford f 250 supercap 2x4 with a 7.3dsi diesel
