fuel pump is pumping but no start
#61
Ok I think its clogged injectors. I have everything off the motor ready to pull the fuel rail but noticed the only thing holding the injector in the rail is a o-ring so when I un bolt the rail and turn the key on to see if the injectors is spraying it will probably blow the injector out of the rail. So how do you check a injector to see if it is clogged or not ?
#62
I hope you can return that computer, know you need to know but jumped the gun dong that. I mentioned it yea but attempt to give overall view what the problem might be based on info so far, did not intend you go get one wish you hadn't especially if you can't return it.
As for testing the injectors there are as many hits via a google search as there are ideas on the subject itself! Check couple three four of them out see what'd work best for you and what you have handy too.
Simple 9 volt, contact switch short section of hose syringe or compressed air should suffice. Comparing all eight before any cleaning should quickly show any with zero or very little flow, show if you have a problem there in need or further investigation/work or not.
#63
#64
#65
#68
Waiting the outcome of the injector work, if where my truck (barring not being there first hand of course and feeling didn't miss anything) it be my next move.
Fairly sure I didn't overlook anything as no one else has chimed in pointing it out?
The "PIP" yes always suspect in no start condition however not in this case, process of elimination done to this point shows it does work. Not a out of the realm of possibility and surly worth mentioning if in doubt yea unfortunately not this time no.
#69
#70
ok danr1 , just thinking out loud until my parts come in to finish my injectors . i'm not trying to put the cart before the horse . BUT , what if clean injectors dont do it ? whats next if anything ? atleast i will have clean injectors right. just wondering what if . you dont have to go into detail just next step . hopefully we dont have to cross those bridges.
#71
Then a sensor jacking off the computer to the point would start/run say MAP for example, however the fact it runs and runs good when you manually introduce fuel strongly suggest there is nothing wrong with MAP and or any other sensor might begin cause the problem.
Everything down the line has come back around to the injectors themselves as the problem, maybe not all of them but enough of them are clogged or otherwise shot to the point no or not enough fuel is being introduced by them to run the engine. Cold start is even worse, even if its 80deg outside its still cold as far as the engine/ect/act/computer is concern, that requires even more fuel yet.
Hopping like heck it starts/runs for you once those injectors have been cleaned, and fully bench "tested" before reinstalling them of course. Making sure all eight do work and work right after been serviced ovoid jump right back in same boat, injectors "function" remain a question mark after all that finding it won't start.
I'm 98-99% sure it will start however if not we'll have to cross that bridge when and if faced with whatever the problem is still remains. Really doubt that will happen....... but imagine that doesn't help much at this point does it!
Oh and again, there are many guys here know as much or more about em as I do, gotta feel one or more of them would have jumped in by this point mention it if I overlooked something.
#73
Time permitted do them myself I would have done a before after test of each one, it be a fairly good way find out if they are the problem.
If no or very little fuel comes through em before cleaning, just runs/dribbles out no spray "pattern" to it but does after cleaning them, now see nice spray pattern from each one that be a good solid sign they are the problem.
Just "cleaning" them no before/after test done, wouldn't really know anything for sure unless it fired up. If any of the injectors simply fail to work even after cleaning just wouldn't know it.
Myself I'd have to know/see for myself, know the injectors did/didn't work before and condition after cleaning them.
You could clean all of them and make it run again, you might end up with 7 that work great but one that doesn't work or doesn't work very well. I don't like the odds after reading some about it, never had trouble with mine yet (knock on wood).
#74
#75
i had the same problem with my 302 i thought it was a fuel problem but it was not it was my ignition coil, Im not sure if this was covered in previous posts but thats what happened, so if you have no spark to the spark plugs of course the fuel will not ignite, again sorry if this was already covered just thought i would bring it up
