how to remove an ignition lock cylinder - Ford Truck Enthusiasts Forums
Old 12-17-2011, 04:12 PM
JwEaVeR96 JwEaVeR96 is offline
JwEaVeR96 is starting off with a positive reputation.
how do i remove the ignition lock cylinder to put a new one in?
Thanks
Old 12-17-2011, 04:32 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Hope you have the key. Place the key in and turn it left to acc, push a paper clip into the little hole and continue turning it left til its flat, then pull it out.
Next with one hand on the bezel reach under the dash and push the switch assembly towards you compressing the spring and twist it counter clock wise until it releases. | <--
guluk
John
Old 12-18-2011, 11:34 AM
EL_Musico's Avatar
EL_Musico EL_Musico is offline
EL_Musico is starting off with a positive reputation.
On my my ignition switch, I first unscrewed the front round plate from the switch assembly and the entire assemble comes out--mine was not spring loaded. Reach behind the dash and gently pull out the assembly and then disconnect it. Then as John mentioned, insert key turn left to the acc position, insert clip into small hole, turn more left until horizontal and pull out the lock cylinder. I guess you can remove the lock cylinder without having to remove the assembly from the dash. It's just the way I did it so I could be more careful.
'08 lock cylinder Late96 2004 - 2008 F150 4 01-21-2015 05:23 PM
stuck steering wheel UaVaj 1999 to 2016 Super Duty 3 10-17-2014 12:23 AM
2002 explorer ignition lock replacement indymike Explorer, Sport Trac, Mountaineer & Aviator 5 12-08-2012 10:18 PM
Ignition Switch Lock Cylinder Removal? tjman 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-16-2009 09:03 AM
Lock Cylinder Removal?!?!? B-DOGG Ranger & B-Series 5 03-19-2006 03:10 PM
Tags
1956, 1999, 2009, f100, ford, ign, ignition, igniton, lock, pull, removal, removing, switch, transit, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
