1955 Blinker Question - Ford Truck Enthusiasts Forums
Old 12-17-2011, 01:43 PM
DGMFORD's Avatar
DGMFORD DGMFORD is offline
DGMFORD is gaining momentum as a positive member of FTE.DGMFORD is gaining momentum as a positive member of FTE.
I started tearing down the dash / head unit on the 55, was thinking of restoring it vs going with after market. I noticed something that was puzzling, the unit has what I'm thinking are blinkers, there is a left and right green arrow on each side of the unit at the bottom. Did the 55 have blinkers? perhaps flashers and not blinkers?
Old 12-17-2011, 04:34 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
All 53-56 instrument panels had them. Turn signals were a factory option. If the turn signals were not installed at the factory tape was put behind the red arrow indicators. The factory installed turn signals even had a cancelling unit in the cup below the steering wheel. If turn signals were added at the dealer, then the unit was mounted on the steering column.....
Old 12-17-2011, 04:37 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Depending on the years, series' of trucks, dealer installed T/S switches may not be the same as the factory installed T/S switches.
Turn signals were an option...at least thru 1963.
Old 12-17-2011, 05:47 PM
DGMFORD's Avatar
Makes sense, I did notice the tape today when I tore the head unit apart.
thanks
Old 12-17-2011, 08:51 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Turn indicators in the dash, whether the truck had signals installed or not, began in Ford trucks in 1951.
Tags
1955, blinker, f100, flasher, head unit, hit, left, turn signal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
