No low beams - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
No low beams
Old 12-16-2011, 11:26 PM
83FordPdx 83FordPdx is offline
83FordPdx is starting off with a positive reputation.
No low beams
2000 f250 has no low beams but the high beams still work. Both sides are doing it? Is this a relay problem?
Old 12-17-2011, 11:01 AM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
No relay on that circuit. You have already checked the fuses hopefully? Check for power on the red/yellow wire going into the multifunction switch, and on the red/black coming out and going to the low beam headlights. If you have power going in and not coming out, it is the multifunction switch.
Old 12-17-2011, 12:20 PM
Do the low beams have a separate fuse from the highs?
Old 12-17-2011, 01:12 PM
Tylus's Avatar
Tylus Tylus is online now
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
yes, you should have 4 fuses if your 00 is like my 06. 1 fuse for each light on low and high...at a minimum you'll have 2 fuses
even if the fuse looks good, pop a new fuse into the spot and try the lights. they don't always look blown
Old 12-17-2011, 07:27 PM
Ok I found a total of 4 fuses. 2 for low beam ( 1 each side ) and 1 for multi switch headlamp and 1 for high beams. All fuses are good. I don't have a way to check the power on the switch. I am in Alaska visiting and he does not have to many tools. The runnin lamps work but no lows.
Old 12-18-2011, 01:14 AM
Well unless you have an extra parts truck with you and just want to start throwing parts at it, you are going to have to do some diagnosis. Doesn't matter that the park lights work, completely different circuit.
Old 12-18-2011, 10:25 PM
Fixed: I did a little more searching and it seems others have had similar issues. And several of those cases turned out to be the low on the lamps burning out at the same time. Which is what he told me. He got in his truck to leave for work turned on his lights and they flashed and went out. Anyways it turned out both lows were dead. Got new lamps and they are fine now.
lowbeam/high beam 1993 bronco mudslinging79 1978 - 1996 Big Bronco 8 05-07-2015 10:46 PM
Flashers don't work, high beams and low beams work texasJ Electrical Systems/Wiring 6 08-09-2014 10:52 PM
HID high beam ?? 05Eddie Excursion - King of SUVs 4 11-08-2012 08:27 AM
high beams dont work, but low beams do? boggerted 1987 - 1996 F150 & Larger F-Series Trucks 2 03-21-2012 03:05 PM
High & Low Beams Simultaneous BAJI26 Excursion - King of SUVs 27 02-28-2011 11:24 PM
Tags
2006, 2008, 99, beam, beams, duty, f250, f350, f450, ford, low, relay, super, superduty, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
