Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-16-2011, 09:23 PM
ptra2417 ptra2417 is offline
Garage is empty, add now
ptra2417 is starting off with a positive reputation.
front disk brake conversion
does anyone know what the difference is between the front axle on my 59 f350 and the front axle of a 59 f100 is? i can buy a power disk brake conversion for a 59 f100 but i dont know if there is any major difference between the two that would allow me to use that same kit. any advice would be helpful.
  #2 (permalink)
Old 12-17-2011, 06:37 AM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
I believe F350's have different spindles than the F100's but can't swear to it. I do know that the F350 brakes are heavier in general. F100 uses an eleven inch drum where the F350 uses a 12 1/8 drum with bigger wheel cylinders and master as well.
  #3 (permalink)
Old 12-17-2011, 07:47 AM
I understand they have different size brakes but it I go to disk it wouldn't matter the size as lone as they fit I just need to know if they will eork
Tags
59, big, brake, conversion, disc, disk, early, econoline, f100, fornt, front, motor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
