Archoil Products - Ford Truck Enthusiasts Forums
Archoil Products
Old 12-16-2011, 06:42 PM
DevilDocTater DevilDocTater is offline
Master of Disaster
DevilDocTater is starting off with a positive reputation.
Archoil Products
I heard about the Archoil line of products from a fellow diesel friend. I went to their website (Archoil brings advanced solutions to lubrication, fuel and corrosion. Nanoborate grease, Nano Borate Oil, Nano Particles, Corrosion, Rust, MotorSilk, LubriSilk,Turkey, Biodegradable Engine, Motor Treatment Lubricants, Motor Silk, Boron CLS Bond Lubri) and read up on their 9100 and 6200 products. Also found a great thread on The Diesel Garage 6.0 section about these products also. I tried the 6200 in my fuel and it made my engine run more quiet and operate smooth. Added the 9100 to the oil and noticed easier cold starts and smoother operation. Not sure if the 9100 did this but i noticed before i added the product my ICP at idle was about 560psi, after the 9100 its running in the 580's at idle. So far its a great product. The company has nothing to hide and provides the science behind how their product works (unlike Rev-X). I tried Rev-X with my last oil change (no reason other than to maybe protect my internal parts) and i didnt notice much difference. So if your up for a good read check it out! Oh and its waaay cheaper than Rex-X.
-Wade
Old 12-16-2011, 08:12 PM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
I work in this industry, in a mind-numbingly boring lab temporary while going to school and can't recommended Archoil products enough. I wouldn't hesitate for a second in using any of their products on any of my cars/bikes. Honestly, if Acrhoil didn't exist I would be producing my own Rev-X clone but with an ester base (far better) and more than Rev-X's laughably low ~1% concentration (in total, after added to engine) not to mention at a fraction of the cost, but since Archoil produces their 9100 with a pretty reasonable profit margin and doesn't lie to it's customers like RevX does, I haven't entered the market though I'm still temped some days when I see the endless Rev-X threads. Again Archoil is good to go and very up-front with it's customers something that is becoming more and more rare these days.
Old 12-16-2011, 08:36 PM
Master of Disaster
I totally agree, the nano technology is going to make lubes so much better and more efficient. Archoil has the best customer service. The CEO is the one that replied at all my emails. They explained their technology to where i could understand it!
Old 12-16-2011, 09:13 PM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
Quote:
HB,
Do you have any experience with Archoil that you can quantify why you would recommend this product? Does it fix injector stiction?
Old 12-16-2011, 11:30 PM
Quote:
Originally Posted by Troy Buenger View Post
HB,
Well, as I've said a handful of times before, Archoil products are some of the go to additives to fend off pointless warranty claims in our gensets especailly one's that are tasked with cold climate/low hours because there is a tipping point for viscosity at low temps that simply necessitates the use of EP/FM/etc. agents. 9100 worked for countless customers, though it's far from the only one, and pre-warranty UOA/virgin analysis/required ASTM specs proves it has the right stuff, which is to say it's a high dose of a now pretty common friction modifier. I've never ran it in a 6.0 for stiction or heard of anybody doing so but I don't see why it wouldn't work, it's got the right stuff and if I had a stiction problem that I couldn't "fix" on my own I wouldn't hesitate to turn to Archoil. With our history with them I wouldn't think twice about trusting them however, this was also two years ago so things (formulation/etc.) may have changed in that time, but I doubt it and I'm not 100% sure it was 9100 vs some other Archoil product but from the description on their site it sounds right but either way it was an Archoil product with a heavy FM/EP dose.
On a side note: Nothing in this realm fixes injector stiction, but products like RevX and the like will temporarily mask it.
Old 12-17-2011, 03:01 AM
Master of Disaster
I didnt have any problems with my truck when i tried the 6200 and 9100 products. But it did make my cold starts unplugged seem like it had been plugged in. The fuel additive made the truck run smoother than 2 cycle oil ever did. If u have stiction problems i would give the 9100 a try, its waaaay cheaper than Rev-X
Old 12-17-2011, 03:10 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Nice information here.......keep it up guys!!!
Old 12-17-2011, 04:18 AM
powerstroker100 powerstroker100 is offline
powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.
how much 9100 do you add to a fresh oil change? (oz) I was going to try revx my next oil change but would MUCH rather try this, going to order from amazon after the new year, I always feel uneasy ordering things online around christmas with how hecktic shipping must get
Old 12-17-2011, 06:28 AM
Master of Disaster
AR9100-16oz treats 14.25 Quarts of Engine Oil or 5 Quarts of Gear Oil
APPLICATION:
Engine oil treat at 28.5 to 1, 1.12 oz treats 1 quart
Gear oil treats at 10-1, 3.2oz per quart
Hydraulic oil treats at 10-1
PACKAGING:
8 oz. bottle
16 oz. bottle
32 oz. bottle
1 gallon bottle
5 gallon pail
55 gallon drum
Old 12-17-2011, 06:48 AM
busdriver47 busdriver47 is offline
busdriver47 is starting off with a positive reputation.
Where do you buy .
Old 12-17-2011, 07:36 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
There is an active thread on TheDIeselGarage on the Archoil products.
Old 12-17-2011, 08:52 AM
Quote:
I wouldn't worry about holiday shipping, at least not yet. Last week I ordered a new camera (Canon T2i) and some law school books from Amazon and got it in 2 days when I was quoted the usual 3-5 days...
Old 01-01-2012, 02:46 PM
I just ordered 16 oz of archoil 9100 off amazon, how long did it take for you guys to get yours?
Old 01-01-2012, 02:49 PM
Master of Disaster
I ordered mine fron Evergreen (Archoils distributor) had it in about 3days
Old 01-01-2012, 04:03 PM
cool, apparently evergreen is in connecticut, about 5 hours drive from me hopefully I'll see it in a few days
real excited to try this
just changed from dino 15w-40 to mobil 1 turbo diesel 5w-40 and its helped a lot, I've read the thread on dieselgarage this stuff seems to work and half the price of revx
Stiction fix, not cure jkey.bama 6.0L Power Stroke Diesel 9 11-22-2016 11:21 AM
Does Archoil really work? 1972fordhighboy2 1967 - 1972 F-100 & Larger F-Series Trucks 7 11-11-2015 06:46 AM
Any Downside to Archoil AR9100 and AR6200? Texas Bob 6.0L Power Stroke Diesel 2 01-08-2014 07:37 PM
Archoil for Stiction? waterboy_fishing 6.0L Power Stroke Diesel 8 08-26-2013 01:27 PM
My first Blackstone amdriven2liv 6.0L Power Stroke Diesel 26 08-28-2012 06:35 PM
Tags
60, 9100, ar9100, archoil, buy, cold, dieselgarage, diesels, engine, forum, garage, guys, oil, protection, rev, reviews, start, treatment
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
