IAC valve - Ford Truck Enthusiasts Forums
IAC valve
Old 12-16-2011, 10:48 AM
86ford185 86ford185 is offline
86ford185 is starting off with a positive reputation.
IAC valve
I posted a thread about my 1988 Ford F-150 with a 302 Automatic that had an idle issue..... I have done some research and believe that my culprit could be my IAC, but I have not taken it off and cleaned it yet or replaced it. Anyone ever had to do this?
Old 12-16-2011, 10:59 AM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
are you having a high idle issue?
if so remove the large air intake hoses from the assembly
and look to the right side "small hole"
truck running plug it with finger
if it idles down --replace IAC
cleaning seldom helps
Old 12-16-2011, 11:08 AM
It idles down and acts as if it wants to die. I believe i will replace the IAC
Old 12-16-2011, 11:18 AM
jr32560's Avatar
Quote:
could be the throttle positioning sensor then
you might want to try cleaning the air intake assembly
be sure to use the correct spray though
they have a coating on em and regular carb cleaner eats it off
Old 12-16-2011, 11:27 AM
norvillebob's Avatar
norvillebob norvillebob is offline
norvillebob is starting off with a positive reputation.
I'm having the same issue, but I don't think it's the IAC. Did you try to unplug it? Mine nearly died, I pulled it off but it was clean inside it.
Fuel Injection Technical Library Idle Air Bypass (IAB)
It's driving me crazy, I did replace the TPS also but I was getting an error code for that.
Let us know if it works, maybe it is my AIC.
Old 12-16-2011, 01:30 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
This has not been my experience at all. Cleaning *always* helps. It's not permanent, you have to clean them periodically. This is very common on Fords. I have never replaced an IAC valve in almost 1MM miles of driving IAC-equipped Fords.
If you are gonna replace it, be sure to use a Motorcraft replacement. The ones they sell at Advance, Autozone, et al, are junk.
Old 12-16-2011, 01:35 PM
jr32560's Avatar
agreed on the junk replacements
and cleaning is a temporary fix
Old 12-17-2011, 02:39 PM
any updates?
Old 12-17-2011, 09:11 PM
I havent had the chance to replace it or clean it yet guys, but I will be sure to let everyone know when I do. The reason I think its the IAC is because I did some research and I was told that If I took the IAC off the motor and took it apart and turned the key on with it still plugged in that the plunger would move in and out but it wouldnt move. They said that if doesnt move that the IAC was junk.
Old 12-18-2011, 12:07 PM
jas88's Avatar
That's like saying why wash your underwear they are just going to get dirty again. The new IAC is gonna get dirty, too. Cleaning the IAC is a periodic maintenance item, like replacing brake pads.
Having said that, it's important to use a cleaner that is throttle-body safe, since the IAC, like the TB, has a coating that prevents buildup of deposits. If your cleaner strips that away, then it's going to get dirty faster.
Old 12-22-2011, 01:21 PM
I cleaned the IAC and noticed a considerable difference in the way the truck runs. I am still going to replace it when i get the money but cleaning it did help!
Old 12-22-2011, 01:38 PM
BrianDguy BrianDguy is offline
BrianDguy is starting off with a positive reputation.
Did it just help, or did it fix the issue? I cannot see replacing the IAC if cleaning it alone solved your idling down issue.
Old 12-22-2011, 07:15 PM
It helped with the Issue, it didnt fix it. It idled really rough and low, but then I cleaned it and it actually wanted to run on its own but it was still rough. Its the original IAC from 1988 so its probably junk.
Old 12-23-2011, 07:24 AM
jas88's Avatar
When you clean the IAC, you must disconnect the battery for at least 10 minutes to reset the ECU. It will then relearn your driving style and adjust the idle accordingly. This can take up to a week for the computer to dial it in just right. I don't know why, but it seemed to take much longer for my Windsor motors to settle in on how they wanted to idle than it did for my 300 Six and current 460.
Old 12-23-2011, 10:34 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
I'd bet You have 2 problems, neither involves the IAC. More than likely You have a vacuum leak, possibly the vacuum reservior. I'd almost bet Your EGR is not fully closing. Prolly caked with carbon deposits.
High Idle and high IAC voltage issue dstrahm Aerostar 6 11-19-2016 10:33 PM
2008 Expedition Quivering while Idling want2learn 2007 - 2014 Expedition & Navigator 1 01-29-2016 07:00 PM
IAC Trouble bkbkbkbk Ford Inline Six, 200, 250, 4.9L / 300 3 09-07-2014 07:08 PM
IAC or Not Blacksmith101 Modular V8 (4.6L, 5.4L) 1 02-23-2013 06:41 PM
IAC Valve cactusbronco 1978 - 1996 Big Bronco 2 08-03-2005 08:01 PM
Tags
150, 1991, 2003, 302, 75l, aic, air, controll, f150, f250, ford, iac, idel, location, motor, picture, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
