IAC valve
you might want to try cleaning the air intake assembly
be sure to use the correct spray though
they have a coating on em and regular carb cleaner eats it off
Fuel Injection Technical Library » Idle Air Bypass (IAB)
It's driving me crazy, I did replace the TPS also but I was getting an error code for that.
Let us know if it works, maybe it is my AIC.
on
cleaning seldom helps
If you are gonna replace it, be sure to use a Motorcraft replacement. The ones they sell at Advance, Autozone, et al, are junk.
This has not been my experience at all. Cleaning *always* helps. It's not permanent, you have to clean them periodically. This is very common on Fords. I have never replaced an IAC valve in almost 1MM miles of driving IAC-equipped Fords.
and cleaning is a temporary fix
I havent had the chance to replace it or clean it yet guys, but I will be sure to let everyone know when I do. The reason I think its the IAC is because I did some research and I was told that If I took the IAC off the motor and took it apart and turned the key on with it still plugged in that the plunger would move in and out but it wouldnt move. They said that if doesnt move that the IAC was junk.
on
Having said that, it's important to use a cleaner that is throttle-body safe, since the IAC, like the TB, has a coating that prevents buildup of deposits. If your cleaner strips that away, then it's going to get dirty faster.
on
When you clean the IAC, you must disconnect the battery for at least 10 minutes to reset the ECU. It will then relearn your driving style and adjust the idle accordingly. This can take up to a week for the computer to dial it in just right. I don't know why, but it seemed to take much longer for my Windsor motors to settle in on how they wanted to idle than it did for my 300 Six and current 460.
