87 f150 skipping - Ford Truck Enthusiasts Forums
87 f150 skipping
Old 11-05-2002, 08:25 PM
fordtough4ever fordtough4ever is offline
fordtough4ever is starting off with a positive reputation.
Post 87 f150 skipping
hi guys, i have a problem that maybe you can help me with. i recently bought an 87 f150 with a straight 6 at an auction with 73000 miles on it. great shape. only 1 problem, it skips or hesitates, not all the time, maybeonce or twice a mile. anyways, i changed the cap, rotor, plugs, plug wires, cleaned the injector, and changed the fuel filter. I thought maybe the problem was that there was moisture in the gas tank because i had no idea how long it had been sitting. i have gone through 4 tanks of gas each with dry gas, and it has not cleared up. after changing the fuel filter and plugs, it ran great for a day and then started skipping again, but not as bad. please help me out with any suggestions you might have. thanks alot!
Old 11-05-2002, 11:19 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
87 f150 skipping
Get a Haynes manual & pull the codes. You'll probably find some EGR faults, but they won't mean you necessarily have to replace the valve.
Old 11-05-2002, 11:27 PM
steve83's Avatar
87 f150 skipping
V10 skipping problem BJG V10 1999 to 2016 Super Duty 9 07-12-2011 07:31 AM
V10 skipping problem BJG V10 Modular V10 (6.8l) 3 06-18-2011 06:07 AM
very confused on my 1993 Ford F-150 6cyl tlamos Fuel Injection, Carburetion & Fuel System 0 09-25-2010 01:29 PM
1990 f150 skipping rweaver1 1987 - 1996 F150 & Larger F-Series Trucks 10 04-03-2008 02:48 PM
98 4.6 Skip/Misfire, no code coming up CTSteve 1997-2006 Expedition & Navigator 3 05-02-2005 11:39 AM
Tags
1987, f150, skipping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
