CA Smog Test Question - Ford Truck Enthusiasts Forums
S. California Chapter Join Chapter, Leader: wpnaes
Old 12-16-2011, 08:17 AM
cmdevildog16's Avatar
cmdevildog16 cmdevildog16 is offline
cmdevildog16 is starting off with a positive reputation.
Good Morning,
As most of you know i will be moving to Camp Pendleton CA the beggining of Jan 2012, I am curious what is involved with the SMOG test for CA as i have heard that no matter where my vehicle is registered if i live there and to register on base i have to have it as well. I am trying to figure this out cause i have just installed a 4" turbo back straight pipe meaning no cat or muff, and dont know if i will be alright or not
Old 12-16-2011, 09:58 AM
stRangerXLT's Avatar
stRangerXLT stRangerXLT is offline
stRangerXLT is gaining momentum as a positive member of FTE.
law states you need everything stock from the cat forward and at least some sort of placebo muffler. some technicians are less picky so YMMV
Old 12-16-2011, 10:07 AM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
I know of several service members in the local SoCal diesel clubs that maintain registration of their vehicles in their home state and aren't subject to Ca smog inspection. If you register it in California you'll have to have all of the emissions equipment that it came with from the factory, as Scott said.
The California test for diesels is pretty simple. Visually inspect for applicable equipment, check OBDII for codes, snap test (rev it up a couple of times) for smoke. No dyno involved.
Old 12-16-2011, 10:15 AM
don't forget he goes on base, federal rules are in play as well
Old 12-16-2011, 10:21 AM
well my truck will be registered in washington state but i think i have a fix for the cat at least for long enough to get it tested...i got some 3.5" to 4" adapters to put it in for the test hopefully i can get by without the muff, i heard that i have to have it to register the vehicle on base
Old 12-16-2011, 10:27 AM
they want to see the OEM or same size as stock diameter downpipe between the turbo and cat
Old 12-16-2011, 10:38 AM
***** Emeritus
Found this regarding the State Of Washington's emissions testing requirements:
Quote:
Diesel Vehicles
All diesel vehicles get an exhaust smoke test
Diesel vehicles under 8501 pounds Gross Vehicle Weight Rating (GVWR) with two-wheel or part-time four wheel drive
These vehicles are tested on a dynamometer. All front wheel drive vehicles will be operated by test station personnel. You may operate a rear wheel drive vehicle on the dynamometer.
Diesel vehicles under 8501 pounds Gross Vehicle Weight Rating (GVWR) with constant 4x4 (all wheel drive) or traction control and diesel vehicles over 8500 (GVWR)
These vehicles get a snap acceleration test. The vehicle will not be driven on a dynamometer. You will be asked to fully press down quickly the accelerator and immediately release it, several times, while the transmission is in park or neutral.
Washington Vehicle Emissions Inspection Program - FAQ
Doesn't say anything about equipment, but it would probably be a good idea to look into it.
Old 12-16-2011, 10:44 AM
well i have a 3.5" downpipe and thats what i think is listed for stock. Also yeah i talked to a buddy up there in wa and he said all they do is put i white board up next to your pipe and look for smoke as you rev it up.
Old 12-16-2011, 12:29 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by cmdevildog16 View Post
well my truck will be registered in washington state...
AFAIK, new CA residents have 10 days to register their vehicle(s), 30 days to pay the fees.
Dunno if US military personnel are exempt...or not.
Your 1976 is also subject to smog testing, 1975 and prior years are not.
Old 12-17-2011, 04:42 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Good Morning,
If the truck did not come with a cat, then you dont need one.
You will NOT fail a SMOG test for not having a muffler. It is illegal (in most cases), but it is not a failure point for SMOG.
Some counties do NOT require SMOG. In San Diego county SMOG is only required in some zip codes. Go HERE to check your Zip Code.
California has two levels of SMOG checks, Basic and Enhanced (along with exempt and sale-only SMOGing). I live in an Enhanced area and the SMOG check consisted of the following
- CEL Check
- Visual inspection for obvious problems
- Smoke test
I was in and out in 10 mins. No tail pipe colonoscopy, no computers no gas cap check. Nothing like that. Dont be too worried. Even with tuners you can pass.
Much of it depends on where you go. Some places like to fail people for things that "aren't CARB approved" because they dont have a sticker, but if you show them the CARB list, the item they failed you for doesnt even NEED a sticker ..
Most places are reasonable, but I have heard of people being failed for a 6637. Even thought its perfectly CARB compliant.
Old 12-17-2011, 04:45 AM
A/Ox4's Avatar
9 ECHO 1
I just saw that you registered in WA. The above is obviously applicable to CA only. But the information is there for you.
Old 12-17-2011, 04:23 PM
hey thanks for the info guys, yes i do have it reg in wa so im hoping that i wont even have to deal with it, and i know for a fact i dont have to change the reg because of being in the military....either way im taking the old Cat with me and have a couple adapters to throw it in if needed.
76' F250 - 390 - New carb causing problems Dave Behrens 1973 - 1979 F-100 & Larger F-Series Trucks 9 02-08-2014 12:52 AM
460 efi Moving to CA Smog? WJones72002 1987 - 1996 F150 & Larger F-Series Trucks 13 12-02-2012 02:00 AM
modified diesel smog in CA Kookadala 1999 to 2016 Super Duty 24 06-06-2012 02:18 PM
SMOG test in Northern Ca... what do I do now? VegasFordSD 1999 - 2003 7.3L Power Stroke Diesel 31 12-02-2011 07:57 PM
Late 99 Ca. Smog test 99350Ron 1999 - 2003 7.3L Power Stroke Diesel 20 06-06-2011 10:46 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1961, 1976, 2001, 2010, 350, ca, cali, california, check, e450, edge, f350, ford, header, register, smog, test, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
