Fuel Pressure Regulator Update Kit Install (Blue Spring)
Old 10-04-2012, 06:35 PM
IT_Dude's Avatar
IT_Dude
IT_Dude is offline
I borrowed an Actron and got 0 codes. Assuming that would read codes for my truck, it makes me feel better that I'm not getting any low fuel pressure codes. On the same topic, I got my blue spring kit from Riffraff Diesel today and I also joined cleanmpg.com and will probably pull the trigger on the ScanGauge2 and the fuel pressure test kit next week.
  #107
Old 10-04-2012, 07:00 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Originally Posted by IT_Dude
Got a recommendation for the gauge?
I use spatechnique gauge (google it).
Pricey but two digital gauges in one.
You could put fuel pressure & egt
or whatever together.
I wanted fuel pressure and voltage.
A pillar pod and still have my grab handle.
Sg2 is also great to have.
I have pics in my gallery.
  #108
Old 10-04-2012, 08:07 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
No critter named low fuel pressure code in the 6.0L PSD
there is not a sensor for that. The code is when you
find bad injectors.
Sean
  #109
Old 10-04-2012, 08:15 PM
IT_Dude's Avatar
IT_Dude
IT_Dude is offline
I thought sure I saw that there was a code for it. Oh well, I'm doing the blue spring upgrade regardless.
  #110
Old 10-04-2012, 08:29 PM
bismic's Avatar
bismic
bismic is online now
Received 2,490 Likes on 1,727 Posts
Mark,
Someone should start a post about how much money you've saved them, but it would probably make you sick seeing how much money you could "make". It is a great thing you do helping everyone out with the Tech Folder and just general knowledge! You'll save me $15 with the recommendation on the ScanGaugeII and about $300 in labor from me reading the tech. folder and doing things on my own. So I'm around $315ish in your debt!
Glad to help, and I appreciate the kind words!
  #111
Old 10-05-2012, 06:33 PM
2112's Avatar
2112
2112 is offline
Is my spring already done?
I have a fuel leak from the top of my Regulator. I can't visualize the crack but when running, fuel is coming out of the top where you put the socket on.
I am the original owner. I did not recall the dealer ever working on the regulator and called them and they confirmed they never touched it, tho they said they tested the pressure and it is good. Not sure why it is leaking now.
My question. I have 2 blue dots on my regulator. I have attached the pic. Does this mean I have the upgraded spring? Heading down to the parts counter for the kit, but would be happy to just swap out the cap.
My truck is a 2006 with 68,000 miles on it.
  #112
Old 10-05-2012, 07:01 PM
raptor131's Avatar
raptor131
raptor131 is offline
It is leaking from the black cap? If so I would buy a fuel filter and then you can replace the rubber o-ring that is there, because I have a feeling that if it is not already torqued to 12 nm it is likely damaged and just removing it to inspect you will most likely need a new one. Is it leaking from around the edges? Or is the cap cracked? Sorry but I'm not sure about the blue dots
  #113
Old 10-05-2012, 08:24 PM
2112's Avatar
2112
2112 is offline
yep it was cracked. I just had the Fuel Filters changed 4 weeks ago at the dealer. I picked up a new cap and O-ring and went over to the Service desk. They said bring in the cracked cap and we will comp you the new one.
Now to figure out whether the spring has been changed......
Will the Scanguage II read fuel pressure?
  #114
Old 10-05-2012, 08:28 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is online now
My original cover had a yellow dot. The cover that came in my kit had no paint markings so the installing Tech would have to mark it. I haven't heard anybody say they do that. My filter housing has some JB Weld or something on the back side. Looking from the inside there are no cracks I can see and no leaks.
  #115
Old 10-05-2012, 09:03 PM
2112's Avatar
2112
2112 is offline
I thought I read in this long but great thread that if the blue spring was installed, they marked the cover with a blue mark?
Put the new cap on, no leaks and the Codes P0261 and 0264 have disappeared....for now.
My Scanguage came today too. Going to check on FICM voltage, will it read Fuel Pressure too?
BTW, I can see the crack in the picture I posted. I guess the low light prevented me from seeing it.
  #116
Old 10-05-2012, 09:17 PM
Rusty Axlerod
Glad you got it fixed! I will CRANK "A Passage to Bangkok" tomorrow in your honor!
You will like the SGII but unfortunately there is no fuel pressure sensor on our trucks for some stupid reason so no way to read it from the data buss. Even if you put one in the provided port on the fuel filter housing it would have to be hooked up to a gauge or one of the other monitors that support adding sensors. Guess I missed the post about the blue dots.
  #117
Old 10-05-2012, 09:19 PM
2112's Avatar
2112
2112 is offline
I should have known someone like you would be enlightened.
Thanks for all your help.
  #118
Old 10-05-2012, 09:34 PM
IT_Dude's Avatar
IT_Dude
IT_Dude is offline
2112,
I believe you asked twice and I didn't see where anyone answered you. From what I've read about it, the ScanGauge does not read fuel pressure.
  #119
Old 10-05-2012, 09:38 PM
2112's Avatar
2112
2112 is offline
looks like I need to add the sensor to make it happen. Then find a way to read it while under load.
  #120
Old 10-12-2012, 02:44 PM
Canadianpowerstroke's Avatar
Canadianpowerstroke
Canadianpowerstroke is offline
Well i have done the rad cap and the thermostat mod and tonight i'm doing the Blue spring. I wish i had it when i did the thermostat lol. oh well.
wish me luck all i have to do is
buy my SCT tuner and should i get a delete or a egr cooler.
See If I do the delete then i need the tuner.
What if i do the EGR Cooler and the tuner and un plug the EGR valve does that make sence.
Quick Reply: Fuel Pressure Regulator Update Kit Install (Blue Spring)
