Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 12-15-2011, 04:56 PM
jason4636 jason4636 is offline
Garage is empty, add now
jason4636 is starting off with a positive reputation.
supercharged 2wd gearing advice
I have a 2007 F150 Roush 500RC, with a ported plenum, smaller pulley to get 10lbs of boost, C.O.P. upgrade, Caltracs trac bars, and custom tuned by Troyer performance. Plus a ground force 2-4 drop And 22" Roush wheels with 305/45R22 tires.
In the spring I am putting on my e-fans, LT headers and a full magnaflow exhaust with x-pipe and true duals.
When I went from 20" wheels to 22" wheels, I felt a little bit of a performance drop. I have 3.73 lsd gears now. Trying to decide on 4.1's, 4.3's or 4.56's. And might try a locker, any suggestions?
Thank in advance for your help
  #2 (permalink)
Old 12-18-2011, 09:54 PM
Raider50's Avatar
Raider50 Raider50 is offline
2005 Ford F-150
Raider50 is starting off with a positive reputation.
well since you've got a 2wd I would try 4.56 and if its to low then go 4.30. being 2wd makes it super cheap as compared to us 4wd. You will lose your top end speed but unless you run higher speed rated tires its actually a good thing. Most truck tires will tear themselves to pieces above 140. With 4.56 it should launch like crazy, you will probably have a hard time putting the power to the ground, but if you can get it to hook up no truck on the road will beat you in the 1/8 or the 1/4.
In fact this is kind of kids way to do it but ill look for you and be back with the results soon. Forza 4 is a racing simulator game and one of the trucks is a 2wd f150, ill change the gear ratios and see what it does to e.t.s and 0-60 as well as cruising speed vs. rpms
__________________
77 Jeep J20 4wd 360 4sp 4.11's
05 Ford F150 4wd Screw 3.73 Roushcharged FTX
11 Ford F150 4wd Screw 3.55 5.0 Lariat
  #3 (permalink)
Old 12-23-2011, 06:31 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
I wouldn't go any higher then 4.30s.
I run 4.10s in my truck with a 23" wheel. Its just fine.
I had to move up to a 30" tire from a 28" tire just to keep off the rev-limiter at the end of the 1/4 mile...LOL And my limiter is set for somewhere in between 58 and 6200RPMs.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
Tags
2007, 2wd, 410, 410s, 456, 46, et, f150, forum, fte, ftx, gearing, gears, roush, supercha, supercharged, times
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
