Zf5 inspection plate
Old 12-15-2011, 04:04 PM
Perdue's Avatar
Perdue
Perdue is offline
Hey just wondering if anyone knows where to get an inspection plate for the flywheel on a 89 f250 zf5?
Old 12-15-2011, 06:29 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
Salvage yards would be your best bet.
Old 12-15-2011, 07:53 PM
Perdue's Avatar
Perdue
Perdue is offline
Yah I've tried the ones in the area for months with no luck
Old 12-15-2011, 07:54 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
I have one from a E4OD, I dunno if it would work on a ZF though.
Old 12-16-2011, 12:46 AM
1stgen3rdgendodge's Avatar
1stgen3rdgendodge
1stgen3rdgendodge is offline
Dumb question but what exactly does it look like? I have to complete ZF5's in pieces and will only need parts to put 1 together so I may have a spare.
Old 12-16-2011, 05:43 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
Its the sheet metal piece that covers the bottom of the flywheel.
Sorta an 'L' shape from the side, with a rounded bottom.
Old 12-16-2011, 06:33 PM
Perdue's Avatar
Perdue
Perdue is offline
It also looks like there's only 2 bolts and from center to center it's 7 and 1/2 inchs
Old 12-16-2011, 09:16 PM
1stgen3rdgendodge
Ah ok. I thought it was something like that. I'll have to look through all the boxes of parts I have and see if I have anything like that.
Old 01-03-2012, 04:59 PM
Perdue's Avatar
Perdue
Perdue is offline
So I found one the other week put it on but now it rubs the flywheel when I had the clutch done I remembered they also put a bigger flywheel on so my question is if it will wreck anything without having it on keep in mind it dose get dirty alot as I use the truck to camp in the bush and get firewood
Old 01-03-2012, 05:35 PM
snaponprofile
If anything they should have put a smaller flywheel on....
Not good for the clutch to be exposed to elements like that. It will take a chunk out of its life, but it will work. Nothing should be rubbing, you might not have gotten the right inspection plate.
Old 01-03-2012, 05:59 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
Just curious, why would they have put a smaller one on??? I was under the impression that a larger diameter clutch is an upgrade to hold more power. And you may need a larger flywheel for that to work.
Perdue, I think its more like 3 or 4 bolts, but they might not all be used. I think one of them is tucked up behind the starter and is a pain to get to.
How large of an area is rubbing? That will wear through in no time at all, and not be an effective covering for the clutch. Can you reshape it a bit to work?
Old 01-03-2012, 06:28 PM
snaponprofile
I was talking thickness, not diameter. He probably had a DMF, so I was thinking they probably put a SMF on and that is smaller, not bigger than a DMF.
High performance clutches are bigger but it is usually friction material and greater pressure plate force that makes the clutches stronger. Also, if the manufacturer wanted more friction cross sectional area, I think they would move in, not out because there is plenty of unused inner space. Plus, a flywheel can only be so big before rubbing on the bellhousing, the DMF's barely clear so I don't know how his could have a noticeably larger diameter.
Old 01-03-2012, 08:20 PM
Perdue's Avatar
Perdue
Perdue is offline
I found the inspection plate off a 1990 and mines a 89 and talked to the shop that did the work this morning and they told me when they upgraded the clutch to a 12" single mass the had to change the flywheel to make it work and also told me they had the same problem they actully still had my old inspection plate and said the just left it off because it was rubbing agaist it
Old 01-03-2012, 08:37 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
That's a little sloppy of them to do that and not tell you about it.
I would imagine you could take a pein hammer to the areas it's rubbing and reshape it as mentioned above to work.
Old 01-03-2012, 09:25 PM
Perdue's Avatar
Perdue
Perdue is offline
Yah that's what I thought and here I am seaching for months for one thinking I never had one in the first place. Yah I'll have to try that in the next couple weeks it wasnt rubbing by much either so should take much thanks for all you input
Quick Reply: Zf5 inspection plate
