PATS Immobilizer Bypass Module
Old 12-15-2011, 12:49 PM
Danspeed1's Avatar
Danspeed1
Danspeed1 is offline
Hello,
I have a 99 Ford F150 4x4 I recently installed a Compustar 6200 Remote Start, Keyless Entry into. The keyless entry works flawlessly. The remote start works with the key in the barrel. I bought a Fortin Key-Overide-All and after spending hours on the phone with Fortin tech support we came to the conclusion that this is not going to work with my vehicle. I went with this unit because I have only ONE 1 Key, however I have come to realize I am going to have to purchase another key. If possible I would like a Immobilizer Bypass that is not a key box style (does not require a key be enclosed inside). I would hope all recommendations are from members who have used and/or have this unit in their 99-04 F150 as the original recommendation for the Fortin unit came from someone who said it would work, who I later came to find out had never used one.
Thanks,
Dan
Old 12-15-2011, 01:59 PM
Archion's Avatar
Archion
Archion is offline
What the system needs is the transponder/pill, pop the little door off the top of your key, slide out the glass pill and tape it up near the column is one idea. The modules I have dealt with in the past still required some kind of sacrificial key for the transponder duty. I think I remember hearing of a bypass that had an antenna and could be programmed to duplicate the pill, but that may have been the Ford unit.
Old 12-15-2011, 03:23 PM
00GT's Avatar
00GT
00GT is offline
I have a remote start on my 03 F150 first you need 2 working keys. I bought a cheap $10 bypass off ebay and it works perfect! No need to hide any key or chip in the column.
Old 12-15-2011, 08:56 PM
Danspeed1's Avatar
Danspeed1
That is exactly what I am looking for.... and which one might that be?
DG
Old 12-16-2011, 01:13 PM
00GT's Avatar
00GT
00GT is offline
DG
This is not the exact one I used but its the same. It will work for you.
http://item.mobileweb.ebay.com/viewitem?itemId=230624361338&index=4&nav=SEARCH&ni d=87417800959
Old 12-16-2011, 06:32 PM
Scalemandave's Avatar
Scalemandave
Scalemandave is offline
Will this work on a 2003?
Old 11-14-2012, 08:18 AM
sureshot-!'s Avatar
sureshot-!
sureshot-! is offline
Try this search key: PATS BYPASS MODULE
Some sellers show model/year compatability.
Old 11-14-2012, 09:56 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
There's really no need to answer year-old questions...
And there's no "Golden Shovel" award for digging up dead threads.
Pele
08-25-2015 02:55 PM
afrank
Computer Chips & Tuners
04-01-2015 02:52 PM
BillyBob69
1997 - 2003 F150
07-20-2005 02:33 PM
Wendell
Electrical Systems/Wiring
10-15-2003 05:03 PM
gmarkie
1997 - 2003 F150
03-11-2003 10:51 PM
Quick Reply: PATS Immobilizer Bypass Module
