PATS Immobilizer Bypass Module - Ford Truck Enthusiasts Forums
Old 12-15-2011, 01:49 PM
Danspeed1 Danspeed1 is offline
Danspeed1 is starting off with a positive reputation.
Hello,
I have a 99 Ford F150 4x4 I recently installed a Compustar 6200 Remote Start, Keyless Entry into. The keyless entry works flawlessly. The remote start works with the key in the barrel. I bought a Fortin Key-Overide-All and after spending hours on the phone with Fortin tech support we came to the conclusion that this is not going to work with my vehicle. I went with this unit because I have only ONE 1 Key, however I have come to realize I am going to have to purchase another key. If possible I would like a Immobilizer Bypass that is not a key box style (does not require a key be enclosed inside). I would hope all recommendations are from members who have used and/or have this unit in their 99-04 F150 as the original recommendation for the Fortin unit came from someone who said it would work, who I later came to find out had never used one.
Thanks,
Dan
Old 12-15-2011, 02:59 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
What the system needs is the transponder/pill, pop the little door off the top of your key, slide out the glass pill and tape it up near the column is one idea. The modules I have dealt with in the past still required some kind of sacrificial key for the transponder duty. I think I remember hearing of a bypass that had an antenna and could be programmed to duplicate the pill, but that may have been the Ford unit.
Old 12-15-2011, 04:23 PM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
I have a remote start on my 03 F150 first you need 2 working keys. I bought a cheap $10 bypass off ebay and it works perfect! No need to hide any key or chip in the column.
Old 12-15-2011, 09:56 PM
Quote:
That is exactly what I am looking for.... and which one might that be?
DG
Old 12-16-2011, 02:13 PM
00GT's Avatar
Quote:
DG
This is not the exact one I used but its the same. It will work for you.
http://item.mobileweb.ebay.com/viewitem?itemId=230624361338&index=4&nav=SEARCH&ni d=87417800959
Old 12-16-2011, 07:32 PM
Scalemandave's Avatar
Scalemandave Scalemandave is offline
Scalemandave is starting off with a positive reputation.
Will this work on a 2003?
Old 11-14-2012, 09:18 AM
sureshot-!'s Avatar
sureshot-! sureshot-! is offline
sureshot-! is starting off with a positive reputation.
Try this search key: PATS BYPASS MODULE
Some sellers show model/year compatability.
Old 11-14-2012, 10:56 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
There's really no need to answer year-old questions...
And there's no "Golden Shovel" award for digging up dead threads.
Paging 2008 - 2010 SuperDuty owners with remote start.Security Systems Pocketlint 1999 to 2016 Super Duty 5 01-08-2017 11:38 PM
Crimestopper RS1-G5 Remote Start ALR1955 1999 to 2016 Super Duty 10 12-23-2016 11:30 AM
14 escape remote start chaostoday Escape & Escape Hybrid 1 12-18-2016 12:17 PM
remote start with key-less entry question fordguy2236 1997 - 2003 F150 2 07-13-2013 10:49 PM
Need some help installing a Fortin PATS Bypass... couple questions 1998F150XLT 1997 - 2003 F150 4 04-12-2013 01:00 PM
Tags
06, 1997, 2010, bypass, bypassing, dvd, f250, ford, fords, ignition, immobilizer, module, override, pats, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
